The Lesson I REFUSE to Learn
This is far from the first time this has happened to me.
After an hour or so, I manage to compose the perfect scene, which I then excitedly begin to render.  Without saving the scene first.  Halfway through the render, my system politely informs me that it has to close Daz Studio.  Which it does.  And then I say words that I haven't said since I was in the military.  Loudly.  Repeatedly.
Friends don't let friends render without saving first.  Why can't I learn that?  Whyyyyyyy?
«1
  • SylvanSylvan Posts: 2,719
    We had a poweroutage today after a render was 3 hours in. I did save it though, but had to wait again for 3 hours, ugh.
  • SixDsSixDs Posts: 2,384
    A few days ago I was working on a character morph that took several hours. Having almost reached the point where i was satisfied with it, DAZ Studio suddenly bailed, taking my morph with it. Had I saved my work along the way? Nope. Bummer. I recently redid the character, and forced myself to save repeatedly as I progressed. Will I ever make the same mistake again? Probably.
  • SnowSultanSnowSultan Posts: 3,803
    You have to drill it into your head to save often, and even as multiple versions in case you need to go back to an old one or one gets corrupted during saving. It also doesn't hurt to save our your scene's poses, camera, and light presets individually in case you have to recreate the scene or if you want to experiment making changes and then revert. It's bad enough when you lose an hour's work, but when you spend a week building a scene like I do, I had to learn to make sure to save everything and often. I swear enough when things go right.  ;)
  • FSMCDesignsFSMCDesigns Posts: 12,851
    This really hit home for me about 6 years ago when I was working on a complex commercial model for a game community in 3DSMax. I had already saved 10 or so different versions at different points in the development of it as i went, but then I found a new way of doing something and found myself progressing further on something I was stuck on earlier and my enthusiasm took it further along than I should have without saving.
    4 hours later I had made a ton of progress and hit the wrong tool action and it caused an error and Max closed on me. It tried to save a copy of what I was working on, but it was corrupted and I had to go back to several hours worth of work earlier and do it all over again. Ever since then I save often in every app I use..
    I hate to admit that I do it all the time. Over and over again. And will again, unfortunately o.O
    Laurie
  • P PP P Posts: 1,189
    Politely ask Daz why most computers shut down when using their program. It's a free software anyway.
    How do you know? Do you have access to the data from eveyones computers?
    I have only had DS crash on me a handful of times (knock on wood)
    Its only taken me three years to remember to save often.  Most of the time.
    Can honestly say I've never had Daz shut down my machine. It's quit on me a few times and hung on me a few times, but never choked the whole computer.
    Laurie
    edited February 2019
    I haven't had it happen often, so I'll use that as an excuse for not saving. wink To further illustrate how I sometimes fail to follow what would otherwise be my own advice, I never actually went into the log file to see what had caused the shutdown. My bad.
    Oh, and no, I have never had DAZ Studio cause the PC to bail, either. Just the "an error has been encountered and DAZ Studio has to close" thing.
    Post edited by SixDs on
  • DustRiderDustRider Posts: 2,904
    Laurie
    Same here, DS has never caused my computer to crash since I started using Win7 (IIRC earlier versions couldn't recover from video card driver crashes, so sometimes I would need to reboot after a video card driver crash). I do occasionally have DS crash, and usually when I haven't saved for a few hoursfrown. You would think after spending 8-14 hours a day on computers using 3D and spatial tech. software for the last 30+ years I would learn. But ...... nope, I still do it (I obviously refuse to learn like the OP) I just get to involved in what I'm doing, and forget to save (and loose track of how much time has gone by).
    I do drill it into my students so they hopefully won't get as much experience as I have redoing the work I just did ... because the software crashed. On the up side though, I'm usually a lot more efficient the second time around, and the result is usually better (or at least that's the story I'm sticking to it).
  • TaozTaoz Posts: 10,300
    Yea, it's just a matter of forming a habit. I always save immediately when I start a new project, be it in DS or other software, and thereafter I save with ctrl+s every time I've made important changes.
  • nicsttnicstt Posts: 11,715
    Ctrl S.
    Use it lots; it's a standard shortcut for all apps; I use it in all apps as they all do it at times.
    The question seems to be why you haven'y learnt your lesson in the first place. I save at the times where I have has crashes before... loading objects/figures, changing shaders, deleting things... regularly and often. So I don't really lose anything anymore. Not saving for an hour or more is just asking for trouble.
  • jmtbankjmtbank Posts: 188
    Daz made me (re)learn a lesson about dealing with my overclock stability, and old fashioned 4 slots of memory on cheap mobo sometimes requiring relaxing of timings.
    [The crashes wern't limited to Daz]  After I sorted my machine I almost never get full system hangs.  Once a month maybe.
  • HylasHylas Posts: 5,283
    I professionally work with a program that crashes all the time, so I'm used to saving my progress regularly.
    But maybe this could be a feature in the next version of DAZ, that it asks you automatically whether you want to save first whenever you click render?
    Fairly simple to script that, I think, and then replace your render button (as long as you use one on a toolbar) or cmd/ctrl-r action with the script.
    I'm a Brycer,   I am used to crashes   But Bryce has incremental saves,  and I do mostly remember to use the feature.   I do however end up with a bloated bryce folder because I have (pick a number) stage saves  each one getting larger as it goes.
  • bytescapesbytescapes Posts: 1,914
    If the DAZ Studio development team want something to add to their feature list, Incremental Saves would be worth considering.
    DAZ Studio saves pretty fast anyway, so simply saving the entire scene file might not be too much of a burden. Alternatively, it could just spool the entire Undo stack to disk as it goes along, allowing the file to be rebuilt from the last known good version. That might make for some slow reloads if you'd done something time-consuming (dForce, I'm looking at you), but I suspect many users would prefer a lengthy recovery process to having to start over from scratch.
  • McGyverMcGyver Posts: 7,097
    Incremental saves that you have control of... at least one of the programs I use gives you the ability to chose a time frame... I set mine to about 30 minutes, because most programs seem to get a little brain fart when they autosave... which is annoying. And at the rate I model stuff a half hour isn’t too much progress vs the annoyance.
    The other option would be to have a little window pop up that asks:
    Hey, Stupid... Apparently you haven’t saved your scene in a while and you have just chosen an option that you might regret doing so without saving... Would you like to save now so you don’t throw the computer out the window again if anything goes wrong?...
    Options:  Yes, Thank you.       No, I feel INVINCIBLE!
    It probably could be worded better, but that’s an option... also that could be an option to turn on or off in preferences.
  • Ghosty12Ghosty12 Posts: 2,081
    That would be ideal, a lot of other programs even games have incremental saving so I am not sure why Daz Studio does not have it.. Because I also have had a quite a few of what has troubled the OP, and I had forgotten to save the scene.. That is why I always now save the scene before rendering..
    I think the combination of hardware has a bit to do with it, and the composition of your scene. The more VRAM the better, and system RAM.
    Ever since I upgraded my GPUs to 1080ti's I have had fewer crashes, actually I don't think it has crashed since. I think many issues happen around the point you exceed GPU memory on one of your GPUs.
    Like when I had one gpu with 4gb and one with 2gb, a lot of times I would get half the scene rendered with transparency and the bottom half was right. Stop the render and Daz gives an error and closes. Sometimes it wouldn't even let me save that render. Upgrading fixed that.
    Then I had my first 1080ti, dropped the smallest card out of the system. I still crashed some, but nowhere near as much. I think those crashes all happened when the 4gb was being pushed to drop out. Once I got my 2nd 1080ti so that both cards are 11gb, I have not had a crash since. Perhaps if I push that memory more I might.
    Post edited by outrider42 on
  • All these comments raise a quetion to me...
    Why doesn't the program have an auto-save built in??
    I have other programs that use the fuction.
    Daz.... an auto save would be a good enhancement to your program.
    Actuially the thought of an autosave fills me with horror;  but then I grew up on incremental saves which always gave me the chance to backstep if something didn't work out quite right.
    Laurie
    I've never had it actually shut down my system. I've had CTD several times but its rare that even good commercial programs don't do that from time to time.
    Already been discussed here https://www.daz3d.com/forums/discussion/comment/4281301/
    +1
    Even though I get caught by crashes every now and then, any program with an auto-save I typically turn it off. Two reasons for that. 1) - it can be as bad as a crash (or sometimes worse) when auto-save kicks in and saves something that you made an error on many steps back, and undo can't even come close to fixing it (incremental save can help you here, but if your working on very large files, it can also eat up disk space at the speed of heat). 2) - when working on large files, it can take quite a while, even several minutes (I have had it take over 10 min.), to save the data, thus making the program un-usable until it's done (I make huge PowerPoint presentations with imbedded videos, oh how I hate PowerPoint auto-save when I'm trying to do some quick changes before right before a presentation - I always turn it off). There is a third instance where I really dislike auto-save. I often use files I don't want to change for quick demos. For a spur of the moment demo, copying large files is less than ideal, and a program that "knows better than I do" auto-saving the demo work is really annoying (or disastrous). I can live with programs that just do auto-backups in case of a crash, if they don't keep you from working while they do the backup. For me, that is the best form of user protection (MS Office programs can do that, as do many Autodesk products).
    So, just as a matter of personal preference, I'd rather blame myself for being stupid and forgetting to save than put up with auto-save messing with (or messing up) my life. Obviously, your mileage may vary.
  • launoklaunok Posts: 807
    This is a lesson I've learned many times, as a typist typing complex maths and science docs years ago and French. Maths & science with all that multitude symbols and graphs and French language using too much signs not really in use in English grammar. I have saved almost every line of typing as to not loose my work! But when started graphic design as a hobbyist, I kind of not using the habit of saving my work regularly until I start using Bryce and run many times in Bryce's crashing issues. Bryce now is my main program rendering scenes. Here I have learned many lessons of saving! I am saving, and keeping, the files I am working on even if it was a tiny adjustment I have made. Just in case! My file names will be called something like scene1a, scene1aa1, etc. And because my laptop do not have much space, I save all those files on DVD's from 1st attempt to final scene before clearing laptop space. I have 2 Dvd's full of files of 1 town scene!! Bryce scenes are quite large! My thinking is maybe I will return to 1st attempt and used it in another way whenever. But I was starting to think to give Daz Studio a try creating scenes therein. Thus far, I have used it only for preparing Genesis and export out to use in Bryce. My knowledge is thus very little of DS. But all I want to add is the importance of saving one's work! Just my input, lol.
    Post edited by launok on
  • I have a big, "Remember to save" sign taped directly above my monitor.
    Then you just need a 'Remember to read the "Remember to save" ' message... wink
