PA Festival - Limited Time Offers **Gift Cards on Sale**
245
  • Scott LivingstonScott Livingston Posts: 4,352
    I was wondering about that as the coupon says- 'unlimited use and for a limited time'. A bit like the irresistible force meeting the immovable object! Guess they mean until the end of the month. I'm still waiting for Smay's PA sale anyway, but not $30 worth, so will probably now wait for the catchup sale. Unless they tempt me with a fastgrab again. :lol:
    I think it means there is no limit to the number of times you can use it during the validity period, but it will expire at some point--they just haven't announced when...
  • DZ_jaredDZ_jared Posts: 1,316
    And circle gets the square.
    edited September 2013
    Right now you can get Michael or Victoria 4 Starter and Pro Bundles for free. All you have to do is purchase items from today's featured Premier Artists.
    If you purchase 2 items you can get either the Victoria 4 or Michael 4 Starter Bundles for free. If you purchase 3 items you can get either the Victoria 4 or Michael 4 Pro Bundles absolutely free. All you have to do is add the qualifying items in your cart, as well as the bundle you want/qualify for (V4 or M4 Standard or Pro Bundle) and use the proper coupon code at checkout.
    Victoria 4 Starter Bundle - VIC4-FREE
    Michael 4 Starter Bundle - MIC4-FREE
    Victoria 4 Pro Bundle - VIC4PRO-FREE
    Michael 4 Pro Bundle - MIC4PRO-FREE
    This is a great opportunity to get $100 worth of products for free. The best part is, you are still saving money on these amazing Premier Artist's stores.
    Post edited by DZ_jared on
  • anikadanikad Posts: 1,919
    Ooh, this is a very good deal.
  • Kevin RyeKevin Rye Posts: 392
    I just put 3 items in my cart from deviney (who is a featured artist for today) and I'm getting an invalid coupon message using "VIC4PRO-FREE".
    Anyone know what's going on?
    Did you have the relevant bundle in your cart as well ?
    Yes, I found that you need to have the bundle in your cart. In my defence I don't think the wording was that clear...
    I just updated the post, hopefully it is clear now.
    Ah, good point. That makes sense. I thought it would "pop in" when you added the code. Derr!!!
    I tried it again with the bundle in the cart and it worked
    Post edited by Kevin Rye on
    I failed to mention that the promotion isn't limited to just 1 order. If you wanted to get both the V4 and M4 bundles you could do 2 separate orders. Each order would need to meet the minimum purchase number of course.
  • Ghosty12Ghosty12 Posts: 2,093
    The special must be over because the codes do not work.. :( Yup not working when I enter VIC4PRO-FREE into the coupon area and go apply I get Coupon code "VIC4PRO-FREE" is not valid.and I have the V4 Pro Bundle in the cart..
    Post edited by Ghosty12 on
  • TotteTotte Posts: 15,123
    Did you have three items from the valid categories on your cart?
  • TJohnTJohn Posts: 11,438
    Hi! Someone needs to fix the PC prices on the new Predatron/Diane products, as only one of the items is showing at the 50% discount. The rest are at 30% including the Bundle.
    Thanks.
  • NeilV_1NeilV_1 Posts: 442
    Thanks.
    This has been noted and highlighted to the PTB. May be a little while yet until it gets fixed as its still a bit early in DAZLand
    NeilV 1 said:
    Thanks.
    Thanks.
    Hopefully in time for the $5 coupon to still be in effect.
  • Cayman StudiosCayman Studios Posts: 1,145
    I don't want to sound greedy :roll: but there doesn't seem to be a way to use both the PAFEST-5 coupon and the MIC4PRO-FREE coupon at the same time. So when I try to buy 4 Festival PA items at over $30 plus the Michael 4 Pro Bundle, I can use the MIC4PRO-FREE coupon to get the Bundle free for a total of $30.42, or I can use the PAFEST-5 coupon to get the same lot for $95.39!
    Is there no way around this?
    I bought both of them yesterday. There were plenty of items on sale for about $5 bucks, but I had plenty on my wishlist.
    I bought 3 items at $23.94 and another 3 at $33.86. So I spent $57.80 and got $200 worth of stuff for free! BEST. DEAL. EVER!
    So just put in two orders.
    It's just too bad that I spent $87 on the M5 bundle less than a month ago or I would have held out. I probably would have been cool with just M4.
  • none_8543none_8543 Posts: 27
    I tried first thing this morning (UK time) adding 3 x Premier Festival low cost items to my basked, then adding M4 Pro bundle, then apply the MIC4PRO-Free code, it correctly discounted the M4 Pro bundle, however I didn't check out, aiming to try later.
    Having gone back to take more time over selecting Premier Artist items I want, then adding M4 Pro bundle, applying the MIC4PRO-FREE, no discount is now applied. I have even tried adding loads of items but none of the codes now apply.
    Perhaps the codes for the Premier Artist sale for the 20/09/13 have now expired, as I guess they started yesterday US time.
    Andrew
    Andrew, I'm in the UK as well, and I've just applied the MIC4PRO-FREE code and it works OK, so maybe you need to clear your internet cache or something. I think the PAFEST-5 code is also working. My query was really about getting them both to work at the same time - more in hope than expectation. Anyway, too late now, I've taken the plunge!
    Thanks, yeah I tried a few times without success, but tried on a different computer and this time it worked. In between time found I had most of the M4 stuff, but it fills in a few extras for M4 such as the textures.
    Appreciate your posting was about a different requirement, but the topic in general seemed the best place to place my query :-)
    as far as I know you can only use One coupon at a time they are not stackable this is why you will need to do two orders to get the different bundles (with enough qualifying items).
    Neil is correct.
  • EwokzombieEwokzombie Posts: 76
    How does this help when I only want one bundle and want to save $5 on top of that with the coupon? Kind of defeats the point in having a coupon if you cant use it.
  • Dino GrampsDino Gramps Posts: 0
    If it helps at all - PC items from the PAs of the day count as qualifying items. That's how I got V4 Pro yesterday.
    You can only use 1 coupon per transaction. Coupons don't stack. So you would need to decide whether you wanted to use the PAFEST-5 coupon or one of the free Michael or Victoria 4 coupons. You won't be able to use both in the same transaction.
  • StorypilotStorypilot Posts: 1,683
    Ok I did it and got V4 pro.
    I was sort of on the fence, but I decided in the end it was probably worth it even for the Wet Maps by themselves, and for the sake of actually finally having Morphs++ for that moment if and when I ever get GenX and want to transfer old character morphs I've collected but never used because I just got them for the skin. Several layers of "if" there , but i was going to buy 2 things today, and it wasn't going to be over 30 for the other coupon, so I made it 3....to get the wet maps. (And that third item was the Fantasy poses, which aside from being neat on its own more than justified itself to me by including a cool sword and poleaxe!)
    Will I use the wet maps? I am not sure. Almost definitely not on V4. I'm assuming I need to go through the load them and save them as .duf process if I want to use them on G2F, right? I'm tempted to render something right now just to say I did. But in any case now I have them for free so that is pretty cool, thanks!
    Post edited by Storypilot on
  • edited December 1969
    Hi there. The code won't work for me, saying is not valid (mic4pro-free). I do have 3 PC items, the free tiki island and the M4Pro Bundle in my cart, still coupon/code not working. Does time zone make a difference? I'm in NY ET zone .Any help? Thanks
  • JonstarkJonstark Posts: 2,738
    Also did not work for me (not that I really care as I already have most of what's the pro bundle for V4 and M4 as it was included with Carrara 8, but I see a couple of items that somehow are part of the bundle but previously weren't available to me). Loaded up my 3 orders, it seemed to accept the MIC4PRO-FREE coupon, but I don't see any trace of it in my account downloads. Honestly I don't know why I bother over something I care as little about as this, but it is frustrating not to get what the deal offered. :(
    Did you remember to put the Michael 4 Bundle itself into your cart too before using the coupon?
    That wasn't made clear as part of the instruction for the deal. The instructions listed on the graphic of the offer were simply:
    Buy Any 3 Festival Items - Get Victoria 4 or Michael 4 Pro Bundle Free!
    Just enter one of the following coupons at checkout (which I did with Mic4Pro-Free)
    'all items must be in cart simultaneously for coupon to apply' which only implies the items being purchased must be in the cart for it to apply.
    I actually sputtered a laugh at the thought of putting a $100 bundle into my cart and hitting the buy button and hoping the DAZ store might mot screw up and charge me. No way was II about to try that, with the poor performance record it has so far, lol! :)
