Shell change color of skin....
Hi guys. I have another question.
I have product which is "shell based skin add on". So it is creating geoshell ... probably not sure. I am new in working with DAZ 3D.
Everything work fine but shell change color of skin. Don't know what to do with it.
When I render it with iray, the skin tone on body part with shell is different than rest of the body.
What to do with it? Do I have to set something in render setting??
I add 2 pictures. You can see that one face is much darker.
Thank you for reply
Which set is it? Is it using Iray or 3Delight materials?
Iray materials.
But this happens even if I use different product. In one product I can choose "with shell" and "without shell". Without shell works perfect. With shell works as I mentioned above. It changes color of skin ...
It may be that the opacity map isn't perfectly black on the sections that should be transparent.
No a checked opacity maps and black is black.
OK I don't know why, but all I mention above is problem in DAZ Studio 4.10. If try it in DAZ Studio 4.11 everything work fine. But that addons are old (3-4 years) so I still think they should work in older DAZ version ...
