Shell change color of skin....
Hi guys. I have another question.
I have product which is "shell based skin add on". So it is creating geoshell ... probably not sure. I am new in working with DAZ 3D.
Everything work fine but shell change color of skin. Don't know what to do with it.
When I render it with iray, the skin tone on body part with shell is different than rest of the body.
What to do with it? Do I have to set something in render setting??
I add 2 pictures. You can see that one face is much darker.
Thank you for reply
473 x 871 - 972K
493 x 864 - 1M
Which set is it? Is it using Iray or 3Delight materials?
Iray materials.
But this happens even if I use different product. In one product I can choose "with shell" and "without shell". Without shell works perfect. With shell works as I mentioned above. It changes color of skin ...
It may be that the opacity map isn't perfectly black on the sections that should be transparent.
No a checked opacity maps and black is black.
OK I don't know why, but all I mention above is problem in DAZ Studio 4.10. If try it in DAZ Studio 4.11 everything work fine. But that addons are old (3-4 years) so I still think they should work in older DAZ version ...
