copy and paste a figure multiple times.
My gosh I'm drawing a blank, watching the tutorials am unable to see what Val is doing. So how do I duplicate models?
Thanks
  • Edit>Duplicate sub menu
    if you do NOT plan on adjusting the dup but just having it in the back ground for filler then you should create an instance from the figure instead.
    Make sure you also adjust the render settings for Instances to be optimized for memory instead of speed.  THis will greatly reduce the amount of resources the instance will require and allow you to have more of them in the scene.
