LOOKING FOR A BLADE LIKE THIS?
UpiriumUpirium Posts: 722
Preferably free or cheap...
I tried using the one from...uh..i don't remember but I need a blade.
I can change the textures so texture isn't a big issue.
As long as it has channels to change the whole thing.
  • M F MM F M Posts: 1,388
    Have you got any more better-lit shots of it? ... it looks a bit like a katana handle with a tapered V-shaped blade (o.O)...
  • UpiriumUpirium Posts: 722
    Let me look. It's not a katana. Idk there's a lot of weird angles of it.
    There's a lot of props of it, but I wanted to use parts from the actual show instead of props for accuracy.
    300 x 169 - 10K
    1280 x 720 - 40K
    1280 x 720 - 46K
    500 x 354 - 58K
    1280 x 720 - 55K
  • Faeryl WomynFaeryl Womyn Posts: 3,737
    It's not a sword at all, the entire thing is round, no flat sides the way a sword or knife is, and in the show it's the only weapon that can kill an angel.
    i know, that's why i said blade...
    edited September 2013
    [removed]
    Post edited by M F M on
    This is actually incorrect. The Archangel Blade has a 3-sided triangular blade (tetrahedron?) with an inset grove going down the middle lengthwise of each side.
    1280 x 720 - 246K
    Post edited by Lissa_xyz on
  • tsaristtsarist Posts: 1,635
    This is the closest I could find...
    http://www.daz3d.com/fast-grab-3d-models/real-weapons
    That should take care of you.
    Best of Luck!
