LOOKING FOR A BLADE LIKE THIS?
Upirium
Preferably free or cheap...
I tried using the one from...uh..i don't remember but I need a blade.
I can change the textures so texture isn't a big issue.
As long as it has channels to change the whole thing.
916 x 570 - 39K
Have you got any more better-lit shots of it? ... it looks a bit like a katana handle with a tapered V-shaped blade (o.O)...
Let me look. It's not a katana. Idk there's a lot of weird angles of it.
There's a lot of props of it, but I wanted to use parts from the actual show instead of props for accuracy.
It's not a sword at all, the entire thing is round, no flat sides the way a sword or knife is, and in the show it's the only weapon that can kill an angel.
i know, that's why i said blade...
[removed]
This is actually incorrect. The Archangel Blade has a 3-sided triangular blade (tetrahedron?) with an inset grove going down the middle lengthwise of each side.
This is the closest I could find...
http://www.daz3d.com/fast-grab-3d-models/real-weapons
That should take care of you.
Best of Luck!
