What hair works for Millenium Girls?
I’ve tried Genesis 1 hair, Victoria 2 hair. Nothing seems to load properly on the head.
Any hair type or specific products you could recommend?
  • Those are old figures, so unless there is still hair made specifically for them you will probably need to load a piece you want to use without fitting it, then manually scale and position it to fit on their head and parent it to the head.
  • CybersoxCybersox Posts: 9,913
    edited January 2019
    It looks lilke there are still quite a few hair items in the store that fit the various permutaions of the Mil kids and teens. To find them, go to the store front page, and select "people and wearables".  That will give you a set of options that includes one that says "hair."  Select "hair" and then go down to the filters section.  Click figure and then type Mill in the white box that appears and that will give you options for all the various mill characters.  I currently show 26 hair items specifically fitted for the MIl Girls.  (Don't forget to click the box that unhides items that you already own.)
    Of course, this won't show you items that are no longer in the store, nor will it show you items from Renderosity or that you may have purchased or picked up as freebies in the past, but at least it will get you started.  .
    Post edited by Cybersox on
  • Ok, thanks guys! ????????
    edited January 2019
    Don't forget that you can parent almost any hair to any head, then adjust it to fit (Do not use fit-to, as that can cause problems). It just takes a little patience, but it's worth that effort.
    Here's a V3 hat/hair combo adjusted to G8F, as an example I recently did.
    800 x 1294 - 608K
    Post edited by frankrblow on
  • pwiecekpwiecek Posts: 1,598
    edited January 2019
    You can load hair that is a cr2 and parent it to the head but irt will not be fully functional. Hair that loads as a prop (hr2 or pp2) EXPECTS to be parented, so it has been designed to work without conforming (fit to) so pp2 and hr2 hair are the best choices.
    Post edited by pwiecek on
