Maxx is green?
tdc
Is this right? Do I have some kind of issue? He looks like The Hulk until rendered... A bit jarring at first.
tdc
I could be wrong but I think it's something to do with DS rather than Maxx, DS's viewport has problems translating the shader, I get all sorts of colours especially when using the Terra Dome 3.
Well, at least it renders properly. Makes me want to try using Terra Dome 3 and see what I get! ;-)
It's because his skin uses a custom shader. Custom shaders show up weirdly in the non-NVIDIA preview.
Thank, no big worry. Once I noticed the render is fine, didn't bother me too much... Cheers
Hi! Yeah, as Will said, custom shaders look colored in the preview. It will render as intended, but if it´s distracting, you can turn On "Per Pixel Shading" in the Interface section of Preferences. I included this in the instructions next to the character for future reference :)
Oops, double posted...
Oh, thanks! It's worth it to use your brilliance! Love your stuff SO MUCH! I look forward to more from you, green or not!
