Sydney 8
1…457910…12
  • jukingeo said:
    Hello All,
    I am just poking my head in here as well and I too am very interested in buying Sydney as I like her overall look, but then I was reading this thread about the breast issues.   Now am I correct in saying that this issue is only with the HD overlay?   Otherwise is Sydney fine without using that overlay?
    As it is, what I don't like is that the HD overlay is something you have to pay extra for.   As it is, most of these figures Daz releases just seem WAY too expensive.  Initially it is OK, but even with the release break Syndey on her own is about $22.
    Even though I am fairly new to Daz, I realized quickly that I was better off just buying morph packages and do the work myself and make my own characters...which was the intention anyway.  However, the morph packages I have don't have many morphs to age the body and I wanted to create an older, but still pretty woman.  So my first attempts at this is pretty much a failure.  In fact I am even too embarrassed to post my first attempt!   I know with the Skin Builder package, that will take care of most of the skin / surface aging issues.  But things like wrinkles and how the face is shaped when it is aged, then I need the morphs for that.   So in a nutshell, buying an older character will get the basics and then I can fine tune with the morphs.     Even though Sydney is very detailed, aged well and still looks attractive, I do agree in regards to the Orange Oompa Loompa spray tan look. In terms of Daz's creations, I would say that I like the Alexandra 8 package best.  In fact I do like the Pro Bundle for Alexandra better than that the one for Sydney.  But even with my Platinum Discount the pro bundle is $94!!   So I am going to have to wait for a sale on her.
    The only downside with Alexandra is that she doesn't seem to be old enough...like if I want to do an older 'witch' look or something like that.   With Sydney, I am sure I can 'dial in' as much of the aged look I want and then go back to my morphs and adjust as necessary.
    I do admit if someone did create an 'aged' add on for Zelara, I would go for that myself.  Her skin is perfect!  I can see a few wrinkles here and there, some nice crows feet around the eyes and of course the laugh lines around the mouth.  She would be an awesome looking older woman.
    In the meantime I found this package:
    https://www.daz3d.com/ej-daisy-and-malmorda-for-genesis-8-female
    The discount with PC this came to $13.17.    Almost $10 cheaper than Sydney and you get TWO older ladies.  I read the description and this package comes with four different skin tones, going from pale to spray tan.   You need the female morph package for this to work with the body.   I am going to say that after buying this, the looks of these ladies are NOT as stellar as the pictures show.   I was hoping that 'Daisy', the heavier set woman with her more pleasant face that I could work with her to make her a bit more attractive.   So that is a work still in progress.  The other woman I am not sure if I could make her pretty, however, her face structure is excellent for an evil witch or scorceress.
    So I am just bringing that up in the event others are looking for an alternative.
    I would still buy Sydney as well if I saw what others did with her, but I mainly would like to know what she would look like without the HD package as I am NOT spending $22 for the model and then ANOTHER $17 for the HD overlay, and from what I understand from reading this thread, that it has issues on top of it.
    Hi jukingeo,
    There are two issues with Sydney. One, the HD morphs which if I understand correctly, leaves a crease in the lower chest area of a figure when not combined with the Sydney base shape (messy). The second issue is the breast deformation on Sydney. It is entirely possible that daz may argue that this is not an issue at all and never fix it. So you will have to morph out the issue which is what ive been attempting. If you want to make your own older characters you should try Aging Morphs for Genesis 8 Female(s), https://www.daz3d.com/aging-morphs-for-genesis-8-female-s . If your looking for a pre made character, one of my favorites is https://www.daz3d.com/grandmother-hd-for-genesis-8-female-and-edie-8 . Also, theres Mabel 8, https://www.daz3d.com/mabel-8 .
    Remember, Daz has an excellent return policy. 30 days, return for any reason. Just make sure that you specify how you want that refund, the daz default is store credit.
  • Oso3DOso3D Posts: 15,125
    HD morphs modify a base figure. Weird results with a different base is not at all unusual.
    And yet, I'm forever using HD morphs (of varying strengths) on different characters other than the one intended and they look fine.
    Laurie
    Laurie
    Morphs move the (virtual, for an HD morph) vertices in a straight line, normals chnage the facing of a surface for lighting purposes. If they are designed for a shape markedly different from the base then using them on a diffrent shape or on the base is likely to produce artefacts. I don't know if it would be possible to separate the head and body HD morphs, perhaps with a fall-off at the neck so they could apply together correctly, but that may well be the only possible approach.
    Allen: Then you're lucky or didn't notice, that's cool.
    Granted, virtually all of my characters usually have clothes on and whatever artifacts exist may be beneath the clothing...lol. But no, I've never noticed a problem. Or rarely.
    Laurie
  • L'Adair said:
    AllenArt said:
    Has anyone put in a ticket? I noticed the flat breast issue too and don't have all the morphs above to fix it. I tried, but they still look less than spectacular. Also, the crease under the breast NEEDS to be fixed. If it were a PA item, they'd be made to fix it. Daz should fix this.
    Laurie
    The issue with the crease under the breasts only occurs when using the Sydney 8 HD morph without the Sydney 8 base shape. Daz may not consider that something to fix. It works just fine with Sydney. The biggest reason I have for wanting it to work with other body shapes is the problem with the breast shape on the base morph.
    I agree the breasts' shape should be fixed. Maybe if all of us file a ticket complaining about how unnatural it is, and how difficult it is to morph into a more pleasing shape, Daz will oblige us with a fix. (But I'm not going to hold my breath.)
    The crease under the breasts is also present on the Melinda add on character. I bought Melinda mainly because I liked the look of the skin texture, I don't have Sydney.
    If you position the camera to get one of the breasts in profile and zoom right in on the underside where it meets the torso, the ridge is almost pyramid shaped. I really don't know what it's supposed to represent. It just looks ridiculous.
  • scorpioscorpio Posts: 8,533
    L'Adair said:
    Laurie
    Is it possible that you are getting that problem because you don't have Sydney?
  • Here is another attempt at the re-shape. I used just the Daz morphs and Breast Control this time. https://www.daz3d.com/breast-control-genesis-8-female-s , https://www.daz3d.com/genesis-8-female-body-morphs .
    Daz Morphs:
    Breasts Gone: 5%
    Breasts Perk Side: 50%
    Breasts Upward Slope: -100%
    Breast Control:
    !Breast Side Smoother: -100%
    Breast Height Upper: -65%
    Breast Sag1: 25%
    Breast Sag2: 80%
    Breast Top Curve2: 15%
    Center Gap Width: 10%
  • scorpio said:
    L'Adair said:
    Laurie
    Im checking now.
  • L'Adair said:
    Laurie
    That only occures if you dont have Sydney. With the Sydney body shape, its not there.
  • L'Adair said:
    Laurie
    Yes, someone mentioned earlier in the thread that you get the crease if you dial in the Sydney HD morph without the Sydney base shape - for example if you were trying to add Sydney's HD wrinkles to another character's shape.
    whatever is causing this distortion of the mesh, is also present in the Melinda character. It obviously shouldn't be present on any of the characters, since it isn't there when you use Sydney HD, so it clearly isn't intentional.
  • Bug submitted for the breast shape. I dont have the HD so I didnt write one up for that issue.
    I'd have to double check, but I think I first noticed the specificity with HD with Victoria 7 on non-Victoria shapes, and maybe Michael 7
  • IldanachIldanach Posts: 217
    Testing out Christian and Sydney
    edited January 2019
    I like Sydney, she has a ton of detail that I felt would be good to add to my GF8 gene pool. Origanally I was going to get the deal on the pro bundle with the free items and the gift card, but after spending time looking at the pro bundle there really wasn't anything in it I wanted. So I have been thinking about it and decided to just get the base character with the HD addon. The orange skin deal isn't that bad IMO and is an easy fix, so it isn't an issue for me as I tweak EVERYTHING all the time and hardly ever use anything stock.. The breast issue isn't that bad for me either since i have found that as long as I have the Sydney body at 50%, it's not an issue and I can add other morphs to it just fine.
    Anyhoo, here is a test image with the HD at 100% and the base head morphs at 50% and the base body morph at 25%, plus many more body morphs to get her where I wanted her to be.
    1463 x 849 - 1M
    Post edited by Chohole on
  • davesodaveso Posts: 8,341
    whoa...thei is really nice. spectacularly good. i might end up buying them just from this render. laugh
  • Worlds_EdgeWorlds_Edge Posts: 2,153
    Great render @Ildanach
  • sapatsapat Posts: 1,735
    xyer0 said:
    From that angle Alabama HD looks like Nicole Kidman.
    I've thought that all along but hadn't seen anyone mention it, so I didn't want to be the oddball.....again....
    Allegra said:
    I wasn't too sure about Sydney but decided to take the plunge and grab her and Melinda, love her look, think she will be one of my favs!
    Quick render of Sydney/ Melinda
    Wow, this combo is gorgeous!
    Thanks @daveso and @Worlds_Edge, it was because of the awesome render by @AllenArt that I decided to get Sydney and I'm glad I did.
    edited January 2019
    This is an ace render! She looks well at home on that bike wink
    She reminds me of the mother from Son's of Anarchy, can't remember her name though
    have you used the HD add for both?
    Yeah I used HD on both, but not at 100%. Think I brought them down to about 65% (I think) and also reduced the normals, bumps and translucency. Got a render cooking at the minute so can't check the exact numbers.
  • nicsttnicstt Posts: 11,715
    L'Adair said:
    nicstt said:
    L'Adair said:
    nicstt said:
    L'Adair said:
    alienarea said:
    Got her, including the HD add-on. Thinking about returning her immediately. When you dial out the Sydney body the G8F base shows a folding-out wrinkle below her breasts.
    I don't believe anyone addressed this definitively yet, so I brought both Sydney and Sydney HD into DS and dialed out just the body morph on each. The wrinkle below the breasts is only there when you remove the body morph, but leave the HD body morph.
    I won't return her because of it, but it's a shame the wrinkle is there. I've been known to use a different body on a figure while still using the HD morph. However, with clothing covering the chest, it might not cause an issue. On the other hand, the added detail around the base of her large breasts adds realism to the skin. After half a century, the skin that's pulled by the weight of the mammary glands has it's own set of lines and wrinkles, something I've not seen in a 3D figure before.
    I didn't do any rendering as it's well past my bedtime, but I wanted to reassure anyone wondering about this issue, that it isn't a problem with the base morph.
    Normal maps can also add such detail; not got the character so cant check.
    In this case, I also dialed out the HD morph and the wrinkle went away. However, I didn't render either one, so I can't yet say how the normal maps affect them.
    A small section of Olympia 8 Normal map; as you can see, that detail at the base of the breast will cause creasing. As, what appears to be, an uncompressed tiff, it will have lots of detail too.
    @nicstt, I think there is a misunderstanding based on the use of the word "wrinkle". Sydney is an older gal and she has lots of wrinkles, which I love. However the issue with the breasts if one tries to use the HD morph with the G8F Base Female is a crease in the mesh. Here is an image I put together in Photoshop from saving viewport draws that should show you exactly what I mean. Normal Maps are off. I have not tried the HD on any other figure/character morph.
    Sydney8 Breast Crease Detail Hd On Base Morph Off
    As many of us like to use the face of one character with the body shape of another, it's important to know about this in advance. I think it would be great if there were a separate morph to dial this out, kind of like the Nose smaller morphs for Ollie and Edie, so the HD morph could be used with other body shapes,
    I've gone back to my earlier posts and changed wrinkle to crease, for clarity.
    The creases mainly relate to bust size; it causes the skin to fold, much like it folks at the groin and abdomen when bending over - even with very slim folks.
  • nonesuch00nonesuch00 Posts: 18,878
    Well, I think you're right. After I noticed the similarity for that angle I could also see if in other angles. Seeing geometry is tricky because noticing the details in it is so heavily influenced by lighting, color, and context.
  • L'AdairL'Adair Posts: 9,479
    L'Adair said:
    Laurie
    I think it's more a case of the artist compensating for the Sydney shape.around the breasts. Sydney is listed as a required product.because the character was created off of the shape of Sydney. It's no surprise, given the sagging breast look of Sydney, that the shape morph of Melinda without Sydney has issues around the breasts.
    HD morphs adds specific detail to their respective figures. In Sydney's case, that includes details to support the look of sagging breasts on a 50-something woman. But to look right on other characters, the breasts need to have the sagging look to begin with. And of the plethora of female body shapes I have in my runtime only one not intended for Sydney looked good with Syd's HD morph. A second one looked okay, but not quite bikini worthy.
    That looks pretty amazing. Great job!
    @jukingeo, Welcome to the wild and crazy world of Daz 3D.
    If you're not too picky about the shape of her breasts, Sydney looks amazing. As an older woman, and a bleeping perfectionist, they bother the h3ll out of me! lol Sydney also looks fine with her HD morph. It's created specifically for her and augments all her lovely wrinkles and other imperfections. The issue with the HD morph only comes into play when used without the Sydney shape.
    I second AnotherUserName's recommendation of Zev0's aging morphs to attain your goal of an attractive older woman. They will work on any Gensis 8 female, including Zelara. You may need to go to the Parameters pane and increase the level of SubD, (Mesh Resolution) to get the best results.
    (Zev0 also has aging morphs for the males, and for both in the Genesis 3 line as well.) I don't recommend blindly buying everything Zev0 has released, but when you have a specific need one of his products is for, I recommend you grab it. (You can save yourself a lot of money if you ignore the sales and only buy what you need when you need it. Even if you pay full price, in the long run, you'll spend less money and have a runtime that's not bloated with a lot of products you end up never using—like my runtime!)
    One more thing, don't be afraid to mix and match. There's no reason you can't dial in another face with Daisy or Malmorda to modify their faces. A little of this, a lot of that, maybe a bit of someone else… And you can apply any G8 female materials to any G8 female. There are lots of combinations that will look horrific, but there are also lots of combinations that will look pretty darn good, too. Be sure to preview in Iray, (or 3Delight, if that's what you're rendering with.) The default texture view in Daz Studio doesn't do any character justice, especially when the figure has Iray materials.
    As an older woman, I have first-hand knowledge of how the skin beneath the breasts creases at various stages of age and breast size. I assure you, my skin has never doubled over on itself into a crease below the breasts. Perhaps I'm the odd-woman out…?
    Regardless, I hope we can agree to disagree on this issue…
  • DkgooseDkgoose Posts: 1,451
    I actually like Sydney, here is two renders, the first is just her with the had morphs and the second one I played with the surgical beauty morphs
    945 x 990 - 1M
    945 x 990 - 1M
