Message for Amaranth re: Clothing Breast Fixers
SickleYield
Please contact Support directly with your questions in the future rather than PMing me. I wrote out an entire reply but the PM system says your screen name is invalid and will not let me reply to your message.
Here it is:
Hi,
The set has no "user facing" files. That means in this case that you access it from the Parameters tab of G2F herself.
When you conform an item to G2F, and it does not fit her chest correctly, select G2F. In the Parameters tab, go to Actor/Chest/ClothingbreastFixers and find the dials that match the dials you used to create your G2F character. Like, if you used V6, find the V6PlusPBM heading and dial in one of those. You use different dials in combination just as you used different morphs in combination to create a G2F character. They will automatically transfer into the clothing without affecting G2F herself.
Hope that helps,
Shalen/SickleYield
The screen name has been fixed now.
test
sorry for some reason i couldn't reply to thread or post new threads
.... for the x'th time typing this ..., i will contact support in future, thank you for your time to reply
