my G8 Male is loading with morphs set - help!
twitchew
So i have no idea how this happened but when i load up G8 (as a default g8 or load a comercial charcter) two characters (christian and james) are already applied.
these morphs are default 0% so i don't know why they are getting applied to my G8 base now.
how can i correct this (without setting these back to zero every time i load G8M.
thank you for any advice.
It's probably some other morph with a non-zero value driving them - if you open their Parameter Settings dialogue from the gear icon (which is, I assume, how you are checking the default values) and look at the Controllers tab the guilty party should be there.
I am seeing this too. This is the first time I have seen a morph contaminate the base figure load, and it is specifically Christian/James, so I suspect a problem with the product. Uninstalling James did decontaminate the base figure. I will leave it uninstalled until I hear further corroboration and/or file a ticket.
