Trouble-shooting your PC membership
2»
  • JohnDelaquioxJohnDelaquiox Posts: 1,197
    DAZ_Jon said:
    Same here my issue was deemed resolved and yet I still do not have my PC account activated. They did not even bother to ask me for my info again, they just sent me the same email twice. Looks like Daz does not want me as a member. I am not going to pay the sign up fee a second time.
    John, your credit card was expired that was associated to your account so that is why we couldn't bill you. We normally don't allow modifying payment information to subscriptions that are expired because it can be exploited with the monthly membership and lack of a sign up fee and hurt the Platinum Club by people picking and choosing which month they want to be a member. However, your case is different in that you didn't get the email notifying of a failure to bill and got turned off without a chance to avoid it. I can manually change your subscription in the database directly to point to a different billing profile and start you back up again, however, I see that when you updated your billing profiles, you removed the old ones and added two new ones and I don't know which card you want associated to your account. Let me know and we can get you set back up. (Note: this is something that CS can't really help with, so if that is satisfactory for you, you can go ahead and close your support ticket on this after you get reactivated. They can tell you why is expired and make small tweaks to your subscription, but the ability to modify billing information and force through billings is something they currently aren't able to do and requires someone on the web team to directly modify the database and run some custom scripts).
    That would be a great help. The profile I use is the USC. Thank you.
  • DAZ_JonDAZ_Jon Posts: 582
    You should be squared away.
  • MarzipanMarzipan Posts: 5
    I'm also kicked out of my monthly membership...What can i do about it ?
    Thank you. I was actually asked to remove the old profiles when I was to add the two new cards.
    It looks like you were one of those people that the old system put in "limbo" so there wasn't enough information to be able to create a subscription in the new system for. You should have gotten an email in early / mid August about us not being able to bill you for the subscription, and the only way, in your case, to get into PC is to checkout with the quarterly or annual membership.
  • edited December 1969
    The last time your account was successfully billed for PC was back in May of 2012. When the new system was brought online, there was no billing information associated to the subscription so the next billing attempt failed and you subsequently got removed from PC. Right now, since you haven’t been billed for it for over a year, the only way to get it going again is to reactivate by going through the checkout process with the subscription.
    I guess I am misunderstanding the charges have been made Paid and deducted from my PP account every month up to and including May June July August and September.I sent proof of this in the case that was closed. The money has been deducted monthly yet membership cancelled please send me a private message.
  • QuietrobQuietrob Posts: 361
    DAZ_Jon said:
    quietrob said:
    This is exactly what happened to me.
    I have done my best to not to complain knowing that changes are often needed. I have stayed positive during all of the changes, revamps etc. Most of all I defended DAZ knowing how much they are needed and how they must remain profitable. I am a positive person and I've encouraged others to remain positive.
    But really. After being a steady member for 7 years...
    For the first time...
    I feel like DAZ doesn't give a damn about us.
    I feel awful.
    Rob, it looks like your account wasn't able to be billed. Our processor returned an error when it tried to bill you for it and it doesn't look like a failed billing email went out when it attempted to bill you (we've added a general catch all to failed billing on the emails as it didn't fall in one of the error codes we were sending the email out on). That should be fixed and you're back in PC now and it should go along smoothly. We've double checked so that if there is any failed billing attempt, it will notify you. Sorry for the delay and the hiccup with it.
    It appears that everything went through smoothly. My account was billed as it was before and I have access to all PC extra's.
    Very good.
    My thanks to Jon and Jack T. for resolving the situation.
    edited September 2013
    After being a long term member i say thank you but no thank you...Adios Amigos
    "After all it wasn't my own fault that i am aware of"
    Post edited by Marzipan on
  • whichypoowhichypoo Posts: 8
    whichypoo said:
    I have been told that daz could not bill me in august for my membership. But what seems really odd to me is that I made a order on 8/5/13 for 25 dollars that seemed to go through . Same card. and if i would reup. I would still be using the same card . I dont want a mixup and my card start getting charged for 2 accounts. so please fix this.
    Thank you
    I'm sorry but I do have one little problem I have been a member since 12/6/2006 I would appreciate if my account would show that date instead of July 2013. It also shows that it will expire October 10 2013. will I again have this problem?
    Thank you for Your help
    Post edited by whichypoo on
  • KickAir 8PKickAir 8P Posts: 1,865
    whichypoo said:
    . . . I'm sorry but I do have one little problem I have been a member since 12/6/2006 I would appreciate if my account would show that date instead of July 2013. It also shows that it will expire October 10 2013. will I again have this problem?
    I've been in the PlatClub since June 2005, but when I put in the ticket that my join-date was still wrong I got "Unfortunately I cannot set you account up to what it was, due to the information being unable to be processed." If that data ( along with my eight-year purchase history for which I've paid a scary accumulation of money over that time) isn't in a restorable off-site backup? What have I been paying for?
  • Daz Jack TomalinDaz Jack Tomalin Posts: 13,965
    The historical information is on record, somewhere, nothing has been lost.
    However, the decision was made to just make the join date (as far as the dashboard) the same is just to minimize the amount of data carried over, so we know we're starting with fresh, known, information.
    From previous conversations with DAZ_Jon, a lot of the old subscriber data is potentially inaccurate, and we didn't want to introduce any rogue data into the new system. As you can see from the issues we have with some of the memberships, there's still a little bit to sort out and square up, but we're getting there.
    Post edited by Daz Jack Tomalin on
  • none_8543none_8543 Posts: 27
    I'm delighted to find that as of tonight (18:00 UK time) the new 3 month Platinum membership that I purchased yesterday for $24, is now correctly discounting items, so for example $1.99 items appear correctly instead of at full price. :-)
    Whilst it was disappointing to see my original Platinum membership end on the 3rd September, despite making payments every month for the past 15 months, I have only lost one month and my helpdesk call is left open in case that can be sorted in the future.
    Thanks to all who assisted, will leave you all in peace.
    Logged on this morning and my Platinmum membership is still active but the $1.99 items are back to full price and I cannot access the members forum. My Platinum membership expires January 2014 yet is having no effect. I guess it lasted about 2 days after being sorted. I'm not happy at all.
  • DZ_jaredDZ_jared Posts: 1,316
    Should be sorted. I'm keeping an eye on your account to make sure it doesn't happen again.
    Post edited by DZ_jared on
    Thanks for sorting and keeping an eye on my account, just updated the other forum not releasing you had fixed it :-)
    Andrew
    Post edited by none_8543 on
  • Muon QuarkMuon Quark Posts: 588
    I too have wished on many occasions to have accurate display information for my account. See my signature.....
    Michele
