I AM BEYOND ANGRY, POSER KEEPS SCREWING UP FACIAL PROPORTIONS
Upirium
It's slight but it still makes me really mad because I can't really fix it for some reason.
This happened yesterday. I saved. I went back. Face looked messed up. I thought it was the pose.
So I restarted it basically.
Saved, messed around a bit, did a render, looked okay, came back; face was like that again.
So I rendered a picture twice, after I saved it, to compare. It is indeed different btu I did nothing different at all in the picture. I hadn't changed ANYTHING.
and it's like this in BOTH saves; the eyes and mouth keep getting messed up.
now I'm probably going to have to do it over again!
I don't know what is going on seirously. Like, the only difference is that I am using someone else's face morph as a base and then I morph said face into something else.
But it wasn't doing this before, I don't think. Now it's doing it.
Is the other person's face morph still dialed in? Since your morph is a morph of their morph, you'll still need their morph present.
It's this face:
http://www.renderosity.com/mod/bcs/vincent-for-m4/69297
I went to the library when I started it, loaded his face, and then aletered it. Worked on it a little bit, saved it, seemed to be okay at first but now whenever I save it, it just does this. Why wouldn't the morph still be in?
I'm just wondering if it's saving only your changes and not the Vincent morph with them.
i expirimented and added the morph again and it seems to have fixed it but i'm a little irritated that i have to reload that morph all the time
hopefully when i save him to my library this won't happen again...
