HDRI Image Previews that indicate different exposures
Could someone tell me if there is a significance to the difference exposures shown in an HDRI preview such as the one attached.  I am familiar with loading an HDRI in DS and rotation of the dome.  However, the image below seems to indicate that I could have different lighting - but am too newb to know if it is accessable in DS.
Thanks for your time.
  • Different settings in the Tone Mapping section of Render Settings, just as a photo will look different if you alter the exposure options.
  • gitika1gitika1 Posts: 948
    Thank you Richard.
  • FishtalesFishtales Posts: 6,228
    I think you will find that the lower picture is the images at different exposures used to make the HDRI in the top image. At 5 exposures that HDRI wont have a lot of light spread. A proper HDRI should go from nearly black to nearly all white over as many exposure increments as possible, at least 16 or more.
  • Yes, on reflection it's most likely what Fishtales says.
    Thank you for your wisdom.
