The My Couch Doesn’t Have The Guts To Talk To Me Or Any Blueberries Complaint Thread.
1…3334363839…50
  • TJohnTJohn Posts: 11,448
    Kyoto Kid said:
    ...well guys it's been fun but I feel I may be on the verge of having my forum rights suspended soon. Won't go into the gory details.
    Life is hell when you are on a fixed income and try to keep up with a hobby that keeps your sanity intact.
    :question:
    If you mean you might have to drop PC membership, I thought that only applied to the Members Only Forum, not the others?
    Don't the rest of the Forums only require registration?
    Or maybe I just don't understand what you mean.
  • SpyroRueSpyroRue Posts: 5,020
    edited September 2013
    Non members can view but not post, Standard members are fine on the forum, just cant access PC forum... But you've dropped out before TJohn.
    KK dont you dare leave us!, We already lost Wooly, we don't want to loose you too!
    Post edited by SpyroRue on
    My complaint today is that my kitchen tap has NO pressure with Hot water... Its no more then 10 meters from the hot water tank, its literally separated by a wall to the Bathroom sink and it has excellent hot water pressure!
    Any sign of a leak? If not, do you have cold water pressure at the kitchen tap?
    If both temperatures appear to be low pressure, check to see if the screening filter on the end of the tap is clogged up.
    516 x 482 - 83K
    I do have cold water pressure, which makes me baffled. I also believe its a separate pipe that sends the hot water to the kitchen then the Bathroom. No leaks inside, and haven't noticed any puddles outside. perhaps somehow theres a blockage somewhere, But I would have thought the pressure build up would have eroded any possible blockage
    How "hard" is the water there? Other than lime build-up in the hot water pipe, I have no idea either.
    OMG it was so simple it belongs in the stupid thread! SOMEONE has been putting stuff under the cupboard below the sink and the hot water tap below the sink was dialed close to closed. :roll: Funny how one will assume the worst and not consider the simple possibilities.
    :lol:
    How many "Someones" live there?
    I have over 1000 files that I have installed with the DIM.
    Now every time I want to use anything to put together a render in DS, I have no idea what the name is, or where it is.
    I always find it eventually, but I spend more time running content searches than rendering.
    If it wasn't for Smart Content and Content Library/Products I'd be totally lost. :lol:
    DIM is magic! I cant believe I held it off so long! After a fresh install, re-installing massive amount of products fully up to date ... Wow. Would have taken me 12hrs to do manually. Now I gotta install all the Rosity stuff.
    Question... Do I need M4 V4 installed to use auto fit with clothing?
  • M F MM F M Posts: 1,388
    Some nights you just gotta sit down and render...
    ... random facial drop...
    (lesson for today people - if you turn Bump setting up too high (like 100%, -0.10 .. 0.10), you may end up with interesting self-intersecting black shadows at the corners of the lips, around the edges of the nose, and the ears. Trick to getting rid of it is to turn the bump setting back down again (v_v)...).
    1024 x 1024 - 868K
    On Genesis? Just the Iconic Gen 4 Shapes for Genesis to get a good fit on their clothing, if I'm understanding your question.
    a morning full of procrastinations. pizza party at the dayjob today, they treating us for a good report card on the audit.
    but first i gotta get there, before that i need to put socks and sneakers on.
    Hopefully that's not all you're wearing, or it's going to be an interesting bus ride and work day. :lol:
  • ps1borgps1borg Posts: 12,776
    M F M said:
    ps1borg said:
    Hey fabulous thx MFM :) Why not weld seams on object export, does it mean something other than welding verts?
    <(^_^)... it's not really my work - originally the script was produced by JWAS84 and Duke533... I just cleaned up the material translation stuff to (hopefully) avoid crashing now when using it with newer shaders. I believe that ExportObj() stuff in the middle there was produced by Rob Whisenant (and nobody has been brave enough to touch it since -- "It works, don't fix it" (^_^)h).</p>
    I _think_ that option might be equivalent to the "Use Bone Welds" option on the OBJ exporter settings pane... and that appears to be only activated when exporting to Poser (there is, of course, no documentation for the DzObjExporter object...). Hmm... is it worth bringing that param out to the UI? or would it be better to just wait and see if anyone complains about it?
    Don't know, is a bit ambiguous so I guess if it aint broke...was just curious :)
    tjohn said:
    ps1borg said:
    Sunrise gave way to grey sky and gentle rain, warm enough to almost have evaporated by the time it hits the ground :)
    Sounds like the same weather we're having. Spring and Fall have much in common. :)
    Persephone rubbin' sleep in her eyes :)
    Heartily endorse that sentiment or lifestyle. She looks great :)
    hey gratz :)
    ps1borg said:
    ... She looks great :)
    ty <(^_^)... the rest of her - "NVIATWAS over there!".</p>
    1024 x 1024 - 264K
    Uh oh. It seems in my efforts to clean install DS and all products I overlooked Spyro's twin Daggers... He had 3 now he has 1 :down:
  • SiscaSisca Posts: 875
    I've found that the search in 4.6 works pretty well if you know the product name, at least for stuff from Daz. If I find I can't remember the name I've taken to firing up DIM and going to the installed products tab, sort by name, and scroll through it until something rings a bell :)
    That has the advantage of being able to take you to the products readme page so you can see the picture and maybe find a file list.
    I've also been slowly but surely adding metadata to all the stuff I have from elsewhere so that I can find it in the searches as well as Smart Content.
    Since I occasionally participate in the Freebie challenge I'd already created a spreadsheet with product names and download links for the freebies so I can search through that to find stuff as well.
    pot O cawffee brewing. someone threw out my milk chug, zealously cleaning the fridge.
    now i can only smell the cawffee til lunch truck comes and i can buy more milk chug.
  • Richard HaseltineRichard Haseltine Posts: 111,862
    No, unlike the gen 3 sahpes the Gen 4 shapes are not required for AutoFit support (or UV sets) - they are purely the user-settable morphs. Genesis includes the Gen 4 UVs and clone shapes as it comes.
    iz that why i feel so drafty? :)
    Ah cool. I assume the actual figures M4 and V4 arent needed for Auto fit to work for genesis... This time around I decided I wouldn't install Gen 4 figures, as simply I just don't use them anymore. If they are indeed needed then I'll install them of course.
  • XyetztXyetzt Posts: 27,575
    My car died on me yesterday but I don't know how or why
    My car died on me yesterday but I don't know how or why.
    I want my car back running and ready for me to go places.
  • DanaTADanaTA Posts: 13,414
    Maybe that's how they do pizza parties in New York! ;-P
    Dana
  • RarethRareth Posts: 1,462
    Dana
    sounds like a fun Pizza party to me, can we all come?
    Dana
    it was a quite pizza spread. pepperoni, everything pizza, meatball. and some side salad. :)
    when luv hits your eye like a lala pizza pie, that's amore
