Truck with strange reflections
Help, this is driving my tiny little mind to brink of insanity.
https://www.daz3d.com/retro-pickup-truck (looks great) But what the hell is going on with the reflections from the glass inside the cockpit. Tried nearly everything to rectify this. Any ideas people ?
The reflections look bad without lighting and shadows etc , but with it ....it's like some kind of trippy kalidascope drug enduced vision :(
  • If that's an OpenGL render, as the title says, then it isn't showing reflections as such.
  • Or did you mean Refractions? The dude's head is looking a bit 2D, and the passenger side door is curved away from the cab. That's some thick glass on that thing.
  • SixDsSixDs Posts: 2,384
    Yes, I think that the glass is acting like a lens, creating the the distortion. (not a kaleidoscope). Perhaps adjusting the surface settings, perhaps the refraction, might solve the issue.
  • Yes, In Open GL it looks great (apart from the res) But in 3Dlight Mr V M8 looks 2d and as you say, the seat and doors go all out of place. I have tried everything on the glass settings but nothing works .... great product but ...it don't work.
  • fastbike1fastbike1 Posts: 4,083
    You will note that the product is for iRay. As such, no guarantees for 3DL.
  • FIXED.
    Look at your Surface settings for the glass in the cab (Glass_Mainbody). There are two places that you can play with to "fix" what you're seeing. The one that I think is best is the "Thin Walled" setting. Turn it ON. I think that adjusts the refractions and relections. The other option I had work was changing the refraction. you can take it to 1.05 or 1.1 The thing is there, real world glass refraction is about 1.2.
