So now I know why skimpwear is so popular.
2»
  • RAMWolffRAMWolff Posts: 10,394
    I don't see why not, on the hang right. Is there an option to export it with morphs applied to it from the model? If so it SHOULD show up with the item stuck inbetween the breasts or where ever. Then you pull it out and set up the mesh how you want it to look. Create a morph for the item and it will look the way you want it to look.
    Uzilite is very good at sharp shoulders - but often gets there by designing the clothes to be used with the upper arms of the wearer hidden.
    THANK YOU.
    Uzilite did/does a great job, but that was M4, this is Genesis, not the same thing at all.
  • ghastlycomicghastlycomic Posts: 2,531
    Arrrgh!!!
    The other annoying thing is high collars that go completely spastic.
    1000 x 1250 - 225K
