Goz
GOZ DOES NOT WORK IN DAZ STUDIO 11 BETA
plugin does not load
Did the versions match? Is it not listed at all in Help>About Installed plug-ins, or is it listed but shown as non-functioning for some reason? Remember that you may have only one GoZ for Daz Studio isntalled at once - if you install for the release version of DS the beta version will be uninstalled if present, and vice versa.
Filename :
C:/Program Files/DAZ 3D/DAZ 3D/DAZStudio4 Public Build/plugins/dzgoz.dll
Name :
dzgoz
Author :
Unknown
Version :
0.0.0.0
Reason :
Library could not be loaded. File is not a valid DAZ Studio plug-in, or was made for a different version of DAZ Studio.
Thank you for your attention
So did you download and install the beta version of GoZ at the saem time as the beta version of DS?
yes, and then reinstalled the latest version
available and still does not work.
However in the previous version of DazStudio it works without problem.
The latest version of both application and plug-in?
try uninstalling the GoZ plugin via DIM, setting up the correct path to your current zbrush installation in DIM application preferences, and reinstalling the plugin.
worked for me.
j
It does not work
It does not work
