Carrarra
Cannot get carrara to load from install manager i keep getting this below so i am wondering how to find " Applications" page of the "Settings" dialog???"
Install Manager cannot find a required path. The installer for "Carrara 8.5 (Win 32-bit)" requires that the installed path for "Carrara 8.5 (32-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
Install Manager cannot find a required path. The installer for "Carrara RenderNode 8.5 (Win 32-bit)" requires that the installed path for "Carrara 8.5 (32-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
Install Manager cannot find a required path. The installer for "Carrara 8 Native Content" requires that the installed path for "Carrara 8.5;8" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
Install Manager cannot find a required path. The installer for "Carrara 8.5 Native Content" requires that the installed path for "Carrara 8.5" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
Install Manager cannot find a required path. The installer for "Carrara Hair Caps" requires that the installed path for "Carrara 8.5;8;7.2" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
On the far right upper corner of the Install Manager screen (next to “Help”) is a little “Gear” icon. Click on that.
The far right tab of that screen is “Applications”.
Path is not there
At the left hand bottom of the Applications tab window there is a little "+' sign.
Click on that and a window will open where you can add a path. The application name, version and bit-rate has drop-down multiple choices. The path you want to set can be "browsed" to.
You need the path for "32 bit Software" in Installations Tab of Settings window.
If it's blank then set your Program Files folder path (usually "C:\Program Files" for 32 bit os, and "C:\Program Files (x86)" for 64 bit os).
