Carrarra
NESS UniverseNESS Universe Posts: 0
edited September 2013 in Carrara Discussion
Cannot get carrara to load from install manager i keep getting this below so i am wondering how to find " Applications" page of the "Settings" dialog???"
Install Manager cannot find a required path. The installer for "Carrara 8.5 (Win 32-bit)" requires that the installed path for "Carrara 8.5 (32-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
Install Manager cannot find a required path. The installer for "Carrara RenderNode 8.5 (Win 32-bit)" requires that the installed path for "Carrara 8.5 (32-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
Install Manager cannot find a required path. The installer for "Carrara 8 Native Content" requires that the installed path for "Carrara 8.5;8" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
Install Manager cannot find a required path. The installer for "Carrara 8.5 Native Content" requires that the installed path for "Carrara 8.5" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
Install Manager cannot find a required path. The installer for "Carrara Hair Caps" requires that the installed path for "Carrara 8.5;8;7.2" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
Post edited by NESS Universe on
  • kakmankakman Posts: 225
    On the far right upper corner of the Install Manager screen (next to “Help”) is a little “Gear” icon. Click on that.
    The far right tab of that screen is “Applications”.
  • NESS UniverseNESS Universe Posts: 0
    Path is not there
    amreidell said:
    Path is not there
    At the left hand bottom of the Applications tab window there is a little "+' sign.
    Click on that and a window will open where you can add a path. The application name, version and bit-rate has drop-down multiple choices. The path you want to set can be "browsed" to.
  • ytetsuytetsu Posts: 46
    You need the path for "32 bit Software" in Installations Tab of Settings window.
    If it's blank then set your Program Files folder path (usually "C:\Program Files" for 32 bit os, and "C:\Program Files (x86)" for 64 bit os).
