Question about the Pretty3D Hot Work outfit
SimonJMSimonJM Posts: 6,084
I am not going to get it, but out of curiosity I had a look and aftergoing through al the promo images for Hot Work Costume, then the product description, and back ot the promo images I decided I was confused.  I think every figure showed in the promos as wearing some form of hosiery but there is no such item listed.  And yet, there ARE 3 stocking matrials listed.  So, are they ani tem, a L.I.E., or what?
Post edited by SimonJM on
  • since they say G8F stockings color where as other textures name the clothing I would assume are LIE or geoshell textures for the G8F
  • fastbike1fastbike1 Posts: 4,081
    It's a pretty clever solution. There is a "legs" surface that just covers the stocking area. To apply, you just need to have the G8F figure selected then double click the desired stocking color from the Hot Work materials.
  • SimonJMSimonJM Posts: 6,084
    Sounds like a L.I.E. solution, thank you both.
    edited December 2018
    @SimonJM
    I don't think it's an actual L.I.E solution because it appears immediately upon applying the shader/material. I believe it just takes advantage of a standard Mat Zone in the G8F model.
    I applied it to a figure from Sabby, then to experiment went to the Surfaces tab, selected the Surfaces:Leg (see attached), changed the base color and duplicated the effect from the Pretty 3D product.
    653 x 593 - 73K
    385 x 380 - 62K
    Post edited by fastbike1 on
    fastbike1 said:
    @SimonJM
    Thanks. If I had been inclined to get the product this would have changed my mind!
