White border artifact on Iray render
juanjoharo
Hi!
I'm working on a new illustration but somethimng weird happens on my renders that i've never seen before, This white halo appers in the borders next to wich has to transparente and i don't know how to remove. When I try to made a composition in Photoshop as usual I do, I can't remove the border even using the matting tool.
Any solution to avoid this white border?
Thanks
What format are you using to save the renders from DS?
It appears in png and jpg... I alwasy worked in saving png to don the compo in photoshop... If you put a color layer in the file attached, you will se the white border but not in the building pictures and is the same scene... that's why i'm confused
I 've discovered the issue... if a remove the crystal from the window, the border disappears. That object has a glass iray shader and for some reason creates this artifacts
