White border artifact on Iray render
juanjoharo
Hi!
I'm working on a new illustration but somethimng weird happens on my renders that i've never seen before, This white halo appers in the borders next to wich has to transparente and i don't know how to remove. When I try to made a composition in Photoshop as usual I do, I can't remove the border even using the matting tool.
Any solution to avoid this white border?
Thanks
500 x 205 - 56K
What format are you using to save the renders from DS?
It appears in png and jpg... I alwasy worked in saving png to don the compo in photoshop... If you put a color layer in the file attached, you will se the white border but not in the building pictures and is the same scene... that's why i'm confused
I 've discovered the issue... if a remove the crystal from the window, the border disappears. That object has a glass iray shader and for some reason creates this artifacts
