dForce Multidress system for genesis 8 female problem
Hello all,
The clothes fit nicely until I run the simulation, anyone can recommend a solution?
Thanks!
https://1drv.ms/u/s!Aj7ggfajPfGtk2XCQu1nP63JNu_L
  • Can you show your settings for dForce from both the simulation tab and the Surfaces tab under simulation? Are you using presets? Try showing a screenshot of how the figure and clothing look at the start of your timeline. I am guessing you are showing the end of the timeline. I recommend that you remove the textures on the figure in case you have to show parts of the figure unclothed.
    Here's more info on handling nudity. Acceptable Ways of Handling Nudity
  • HI sorry for the late reply: I applied the multidress system default simulation system settings (from utilities) and its going well. Thanks for assistance!
