keyframing master objects
Hi
I am trying to keyframe the depth of a text object.
I can keyframe the text master object (size, depth, etc.), but it's as if nothing happens to my instance of the master object. What might I be doing wrong?
/Donleavy
Hi
/Donleavy
Not quite clear on this question, but my guess is this.
If you have grouped objects you can not use the TOP level of the group to scale in a single direction.
If you have 5 items grouped you cannot scale a single axis on all 5 using the top level of the group.
In the motion tab you CAN scale in all directions. ie make the object half it's size by scaling down x y and z 50%
If you wanted to scale just the depth ( y axis) on all 5 objects, you would have to select all 5 instances and NOT the one with the
group name and you could drag the scale control on all 5 effecting only the y axis.
So you can do it, just not from the " Master"
Hope this helps
8068
