Application or Script to Make Mirror Poses
Is there any script or application that can quickly and easily make a mirror pose? I'd love to be able to click on a character, and choose "Mirror this Pose," and have it happen.
  • nicsttnicstt Posts: 11,715
    You don't need either.
    Apply the pose; Edit > Figure > Symmetry
    Node: Root
    Propogation: Recursive
    Direction: Swap Left and Right
    Trunk Nodes: Mirror Accross Y Axis
    Are whay you usually need
    Rob says
    "Edit > Figure > Symmetry... --- Parameter pane option menu > Symmetry... --- Shift+Y"
  • inquireinquire Posts: 2,460
    Tried the first one: it Works! I'll also try the second version. Thank you both so much. I reallly apprciate the help.
  • User rsg over at sharecg has some nifty scripts to do that and more. Look for sgapps-posing-scripts.
  • marblemarble Posts: 7,500
    This.
    Works perfectly for me. I added the mirror pose and a couple of others to my top menu for easy access.
    edited December 2018
    Shift+Y
    Under Preferences, there is an option to make that your default so that you dont have to select it all every time.
    339 x 451 - 14K
    Post edited by Mattymanx on
    Thank you for all of these tips.
    Thank you very much. I did download the zip file. I haven't tried the scripts yet.
    Node: Root
    Excellent!
    Thanks very much. yes
