Application or Script to Make Mirror Poses
inquire
Is there any script or application that can quickly and easily make a mirror pose? I'd love to be able to click on a character, and choose "Mirror this Pose," and have it happen.
You don't need either.
Apply the pose; Edit > Figure > Symmetry
Node: Root
Propogation: Recursive
Direction: Swap Left and Right
Trunk Nodes: Mirror Accross Y Axis
Are whay you usually need
Rob says
Tried the first one: it Works! I'll also try the second version. Thank you both so much. I reallly apprciate the help.
User rsg over at sharecg has some nifty scripts to do that and more. Look for sgapps-posing-scripts.
This.
Works perfectly for me. I added the mirror pose and a couple of others to my top menu for easy access.
Shift+Y
Under Preferences, there is an option to make that your default so that you dont have to select it all every time.
Thank you for all of these tips.
Thank you very much. I did download the zip file. I haven't tried the scripts yet.
Excellent!
Thanks very much.
