G8M Bending Glitch Help Please
almeidapalmeidap Posts: 24
The below image is happening to all my G8M figures....the image below is just plain G8M sitting.  How can I fix this? (See Image)
(Please use an image that follows the guidelines here  https://www.daz3d.com/forums/discussion/3279/acceptable-ways-of-handling-nudity#latest  ~Mod)
Post edited by Cris Palomino on
  • almeidapalmeidap Posts: 24
    edited November 2018
    Image is here this is a gen4male no genitalia on him, no textures
    Image did have textures and was using a bar to cover the groin, removed
  • That looked as if you had a shape or character installed which was applying its corrective morph to the bend even when the shape was not itself applied. If you enable Show Hidden Parameters in the Parameters pane option menu (the lined button in the pane's top corner, or right-click the tab) and look at Currently Used you will see all the corrective morphs in effect - try zeroing those until you find the one that is causing the issue, then post its label here.
    You most likely will need to make a JCM.. there are some videos on youtube on how to make them. PUt an image with some underwear so we can at least get an idea.
  • Here's an image...with shorts on :D
    https://sta.sh/01a9vaocp7gh
    That looks more like a JCM firing when it shouldn't, there may be something installed that is erroneously firing when the figure is bent. With the property tab selected, click on the button shown in the image and then look at current properties.. it will show all morphs that are active.. check anything with JCM or MCM and see if there a name or figure that's being reference that you don't think should be active, such as if you have a human figure showing but you see a jcms that mentions a creature you installed, for instance if you bought a troll from the store.
    259 x 338 - 22K
    Post edited by Male-M3dia on
  • Did you try checking for hidden morphs on the figure with Show Hidden enabled, as suggested above?
  • I have checked hidden morphs but there is sooo much not sure where to begin, started last night but will be giving both ideas a proper test today and will let all know how it works out.
  • It was the Hippo man morph that was popping up.  Got rid of that, fixed the issue.  Thanks, it looks like I'll have to rid myself of the ManHippo...which I've only used once...how do I uninstall him?  The old system used to have an uninstal application...
    Oh but first a big thank you to all!  And I think I finally found how to post an image directly in my post...12 plus years with Daz and I'm just learning now.
    1920 x 1040 - 564K
  • Please report this to support so that the product can be updated.
    How did you install? In Daz Install Manager there should be a button next to the item in the Installed tab; if you installed with Connect then find the product (e.g. in the Products tab of Smart Contnt), right-click, and select Uninstall; if you installed manually you will need to use the file list linked from the redme page to find the files and manually delete them.
