Cartoonized is awesome
11112141617
  • carrie58carrie58 Posts: 4,167
    hmmm I'd ask how was it installed?
  • It was installed with the install manager.
    Try uninstalling it then reinstalling see if that helps
  • Uninstall and Reinstall did not help.
    hmmm I always install manually soooo may we can get somebodyelse to chime in here
  • barbultbarbult Posts: 27,343
    edited November 2018
    Big glasses for big eyes:
    1600 x 2000 - 2M
    Post edited by barbult on
  • I read the whole thread and have a couple questions I didn't see an answer for as I read.
    The first being this.... AllieCatBlue stated she used redz tutorial to transfer to G3F...what tutorial is this and where do I find it, also is the transfer talking about morphs or textures?
    The second is for Barbult...you mentioned you removed some maps to make the hair look more toon. Any chance you have a brief tutorial or suggestion on what to do so I could try this?
    Third is for Divamakeup. Though I haven't tried yet, I did buy the IRRSY (I might be remembering the name wrong) for converting iray to 3Delight and wondered if this would work on your toon skins and/or if you will be including a 3Delight version of the product?
  • ArtiniArtini Posts: 10,842
    That is great, Barbult, and I like eyelashes very much.
  • nonesuch00nonesuch00 Posts: 18,863
    It's there but not so easy to find. Go to the paramters tab with the desired G8F or G8M model chose and in the 'search' box at the top of the paramaters tab type 'cartoon' and you will see the 'missing product'
    Post edited by nonesuch00 on
    smileyI dialed in the Cartoon Lashes.
    I selected the hair in the Scene pane and opened the Surfaces pane. Then in the surfaces pane I selected all the hair surfaces other than the scalp and removed the image maps from the surfaces like Base Color, Cutout Opacity, etc. Don't remove the scalp Cutout Opacity. Just experiment. To remove an image map, click on the little square image icon and select None.
    Cartoonized Kichiro, and also Masako and Yuan from East Asian Women for Mei Lin 8
    https://www.daz3d.com/kichiro-hd-for-lee-8
    https://www.daz3d.com/east-asian-women-for-mei-lin-8
    1000 x 1300 - 240K
    Post edited by Artini on
    There are all files for Cartoonized are available.
    If I move one of the cartoonized sliders, there is no change to the model.
    All other controllers that have nothing to do with Cartoonized respond properly
    and there are changes to the model.
    Well I'm actually doing a render with a Cartoonized model now & those controls won't even show up unless a model that has them is selected so the controls sliders do work. If you are using iRay Preview mode for your viewport view maybe that is the problem? Try Texture Shaded mode for your viewport mode and you should see slider changes with Cartoonized almost instantly. Some of the slider changes are more subtle than others. Since Cartoonized works fine for me I can't think of why yours isn't. Sorry
  • FenixPhoenixFenixPhoenix Posts: 3,227
    Be sure to add (value/percentage) first to the slider called "cartoonized" which shows the full figure as an icon. If you don't, the others may give you more subtle results than you're expecting. If that doesn't fix it. Then try uninstalling and reinstalling the product.
    Post edited by FenixPhoenix on
  • Aave NainenAave Nainen Posts: 1,108
    Just recently started playing with this, lol, gotta say it is so much fun to play with I'm getting very little work done.
    This is Charlotte 8 with Cartoonizer applied and a bit of playing with shader to make the textures look less "human".
    I lied, first pic is base G8 with modified Charlotte texture, second pic is with Charlotte morph added in.
    1000 x 1300 - 458K
    1000 x 1300 - 444K
    Post edited by Aave Nainen on
  • MollytabbyMollytabby Posts: 1,163
    I love your toon Charlotte!
    I can only agree - looks great, Aave Nainen.
    edited December 2018
    Now we got a nice and unique smiles for our Genesis 8 Female based characters:
    https://www.daz3d.com/20-unique-smiles-hd-for-genesis-8-females
    Below is an iray render of cartoonized BD Bronte with Unique Smile 01 HD
    https://www.daz3d.com/bd-bronte-for-the-girl-8
    https://www.daz3d.com/layla-hair-for-genesis-3--8-females
    1000 x 1300 - 216K
    Another example of her - with Unique Smile 02 HD
    1000 x 1300 - 244K
    edited January 2019
    Cartoonized Christian 8.
    1000 x 1300 - 246K
    Good to see Cartoonized is effective with so many render themes too...here are two I recently did as well.
    Although Cartoonized is most effective for closeup portraiture renders with such realistic materials. I think in the future I should pick out more cartoonized shader materials as well.
    Looks great, nonesuch00.
    Cartoonized is my go to solution for many of my renders.
  • LotharenLotharen Posts: 282
    Those are pretty cute!
    edited March 2019
    Bridget 8 with cartoonized applied.
    1000 x 1300 - 342K
  • ghastlycomicghastlycomic Posts: 2,531
    Artini said:
    I am a bit dissapointed with Surgical Beauty, especially after watching the documentary about Hedy Lamarr
    That is nice. I bought Joe Quick's Toon Boy & Toon Girl today & they at 25% on character make good 'child morphs' of the same characters 'Cartoonized' at 100%.
  • Bunyip02Bunyip02 Posts: 9,322
    Vroooom
    Thanks a lot, nonesuch00, and great tip on Joe's Quick toons -  have to try them for myself.
    edited March 2019
    Nice looking toon image, Bunyip02_Carrara.
    Which character is in it?
