Evilson for M4 not installing (apparantly)
krickerd
Am using the install manager and Evilson, unimesh fits, and Dragon Mage are nowhere to be found. IM says that they are installed. Other products which I purchased on the same order DID install correctly, such as Aging Morphs for Genesis, so I know my install path is correct. Also, I've installed products with IM before which have worked. Anything I should try?
If I can't find what DIM installed, I select the product in the Installed Tab, right click and select Installed Files. DIM displays where the files were installed. If any of the files were moved or deleted by myself they display ghosted.
As a general rule, anything installed in the Runtime/libraries will be in the Poser Formats content library, anything outside of the Runtime folder, sans the data and readme's folders, will be in the DAZ Studio Formats content library. If I subsequently move or delete the installed files, they will display ghosted from then on.
Okay, nevermind, I found it: Daz Studio Formats - My Library - People - Michael 4 - Clothing - Evilson - Dragon Master
See, this is why I categorize things. So I can find them later. I wonder why nothing came up when I did a search for Evilson in my Readme folder? This is how I get info on many products I buy and it usually works.
