Dforce for small shapes?
I find that if I use a much smaller shape than the dforce clothing was used for, the clothing tends to explode. For example, if I use a chibi or child shape for Genesis 8 with a dforce skirt- even tho it's autofitted to be smaller, it explodes and falls off when I try to simulate. Is there a way around this, or does special dforce clothing need to be made for smaller shapes?  Would greatly appreciate the advice, thanks.
    I'm not a dForce expert, but I think what you might be running into is that when you reduce the size of the mesh, the density is becoming a problem. At larger sizes, folds and creases are working out fine, but when the vertices get too close together, self-collision may be causing it to explode. The only thing I can think of is to maybe turn off self-collision to see if that helps keep the fabric together?
  • RGcincyRGcincy Posts: 2,864
    You may also try to increase the scale of the figure/clothing before the simulation, then reduce the scale after the simulation is done. As JonnyRay points out, density of the mesh can affect results as does the size of objects.
  • Aave NainenAave Nainen Posts: 1,108
    Another thing to try when scaling way down is to reduce Bend Stiffness in your surfaces settings.
  • Thanks guys, i will try these! Very much appreciated!
  • Updated to add... i used decimator to lower the detail on the clothing for a smaller shape, and it worked perfectly to dforce drape afterwards!  It did indeed fix the density problem. Woot! Thanks again :)
