New Rendering Build
So I recently purchased a Ryzen 7 1700 and paired it with an X470 motherboard and a GTX 1070 from EVGA. I am trying to figure out they are worth upgrading to a Ryzen 7 2700 or 2700X and a RTZ2070.
  • Can your video card do Iray?
  • The DS 4.11 Public beta supports 20x0 cards, the current release build does not.
  • Yes it can do iray.
    And I don't mind waiting on the next release before upgrading.
    Upgrading your CPU would not grant much benefit. Upgrading GPU would offer the most bang. Now there are a couple things to consider. Are you talking about swapping the 1070 for a new card are using a 1070 plus a new card? This is important. A 2070 would not offer as big of a boost as running a 1070+2070. Since both cards have 8 GB, they would would work well together and combine their CUDA cores. VRAM does not stack, but CUDA does.
    To compare your 1070 to other cards, there is a long benchmark thread in my sig. In that thread you can download a scene to bench, and compare that to other user's times. Then you can use that info to decide for yourself. Nobody has yet posted a 2070 time, but I think there is a 2080. I also made my own bench which is my sig as well. Do keep in mind that different versions of Daz can effect times.
  • GatorGator Posts: 1,320
    The CPU upgrade would be an improvement, but so small to be only noticable in benchmarks.  UserBenchmark puts it at a 4% difference.
    https://cpu.userbenchmark.com/Compare/AMD-Ryzen-7-2700-vs-AMD-Ryzen-7-1700/3957vs3917
    The GPU will offer a much bigger return, especially if you run both the 1070 plus a 2070.
  • Thank you all.
