Dystopia City Blocks
Trying to use Dystopia City Blocks, but folder in Content Library is empty. And i cant find it at all in Smart Content.
Installed with install manager. Files are there, i looked at them.
What should i do? Pls help.
  • edited November 2018
    Maybe you can try open DIM find them in installed area, and click on the arrow menu for re-install...
    1600 x 232 - 96K
    Post edited by marco_pasqualini_foto on
  • Which product is that? There are some in Lightwave format, which DS won't open at all.
    I believe you have to look in your Poser library/props or possibly figures.
    Edit: My DAZ3D Library/Props /Dystopia
    Post edited by Sven Dullah on
    Tried it, didn't help. Same empty folder.
    https://www.daz3d.com/dystopia-city-blocks-001-010-lwo
    Yes, it is, apparently, lightwave.
    No, nothing in props, poser or daz. Only dystopia i found is in main foder, like on screenshot i posted earlier. I did file search, it is only folder with such name that exist.
    Ok then you need to find the poser versions, as Richard said those will not work in DS unfortunately.
  • Strange ... Why did they sell them in Daz store then? If it didn't work in daz studio?
    IIRC the product page says they are for lightwave. You can ask for a refund within 30 days from purchase. The ones you want are in poser format (pp2).
    Well i got it for free so it is not money issue. But i want to use it. And poser variant dont exist anymore. Google seach result send me here https://www.daz3d.com/dystopia-city-blocks-001-010-poser and it 404.
  • You could try importing the LWO file into Blender, export as OBJ, and import that into DS, then apply maps.
  • LeanaLeana Posts: 13,620
    Daz sells quite a few products products not intended for DS, products for Bryce or Carrara for example.
  • pwiecekpwiecek Posts: 1,598
    These products are from before there was a Daz Studio.
    Dystopia works, as I remembered, in my DS without issue frown I also downloaded it for free 1st time I downloaded DS...it includes a Poser format that works in DS.
    I've also citybloks 11-20 and works.
    So uninstall it through DIM and try to download/install again.
    1600 x 900 - 622K
    There is no .lwo un import menu.
    I manage to export it, but textures didnt load it daz, building is white. Open3dmod says they are exported too
    From log: ... E:\daz3d\stuff\Dystopia\Textures\Rooftop-Bump.jpg -> e:\daz3d\stuff\Dystopia\CityBlocks\1\textures\Rooftop-Bump5_.jpg
    You have poser version. It is not available anymore... Only lwo version.
  • DAZ studio rarely loads textures from obj even it's own exports you just have to manually add them all
    the only times it ever does is if the obj is in the same folder as the textures but even then it depends on the mtl file
    other softwares I have seem to have no trouble finding paths
    The assemblies that create larger collections of buildings use geometry swapping. At the time these buildings came out, DS did not support it so only individual building props worked. Has this changed?
    Post edited by pwiecek on
  • ed3Ded3D Posts: 2,653
    edited April 2020
    _ yeah,    Use older Blender 2.49b ( download on Blender website) _ and will require Python 2.6.2
    _ and  for Bryce or Carrara         _  Carrara 7Pro will import these  _  Bryce 7Pro didn't _
    Post edited by ed3D on
