Has Dynamic clothing control been removed from Daz all together.
Pennes From Heaven
I have some wonderful clothing that I use with the dynamic clothing control plugin (purchased plugin not standard) and have relied on it quite a bit but have only used it on and off since dForce came out, trying to give dForce a chance to prove itself. After upgrading to Mojave ( and then reverting back to High Sierra, what a mess) Dynamic clothing control no longer shows up as a choice in the panes at all. Uninstalled and reinstalled but even the free plugin doesn't show as a choice. I haven't used dForce much at all due to terrible lag and inevitable crashes of Daz, too much time wasted. If the Dynamic clothing control is no longer an option, I have clothing taking up space in my runtime that are of no use to me. Maybe I am the only one, but dForce just isn't a replacement for Dynamic Clothing Control for me. If the plugin has been removed entirely, my vote is to please bring it back!! If it hasn't, please tell me how to get it to show back up as an option in the program again.
Make sure that you isntall DS before you instal the plug-in, otherwise it will be overwritten by the basic version.
Neither one is showing up, I know the tricks of installing the paid for plugin but there isn’t any dynamic plugin listed in the pane choices even though it shows in the installed plugins.
What colour is the status icon on the installed plugins dialog?
Did you re-enter your serial number?
It shows installed with number filled in just like it did when it used to show up in the panes but no dynamic pane to choose from at all, like it doesn't even exist any more. I am going to try to download it and install it manually again and see if that makes any difference.
Got it, had to go through all new registration process even though serial numbers were all there. Had to do it for Daz Studio itself even........Well thanks you 2 for the help, all is well now.
If it was showing the serial number it probably wasn't - it was showing the box for the serial number, with the first few characters (to show the pattern) followed by Xs all in grey text - the idea being to guard against people entering the wrong numbers in the boxes.
