Installing Hexagon through DIM
How do you install Hexagon and the beta and get them to go where you want them. I have a path listed under Applicaitons in DIM that points to where I want them to go...on my D drive. But when I install them, they keep going to my C drive and it creates new paths under the Application tab where it decided to put them. So I end up with 4 paths for Hexagon on the Application tab,.Or should the paths be listed under the installation tab? Right now the only paths on that tab have to do with DIM itself.
  • namffuaknamffuak Posts: 4,467
    Software installs to the 32-bit and 64-bit directories listed in your installation tab - and then updates the path in the application tab. So change the default 32 bit and 64 bit installation directories to point to your D drive - and make sure they are different directories. I use D:/bits-32 and D:/bits-64. Note that these will become your Studio install directories as well if you delete and reinstall studio.
    I do the same, but use "D:\Program Files" for 64-bit and "D:\Program Files (x86)" for 32-bit. I'm lazy and that means I only have to change the letter at the beginning to redirect the installation paths. :)
  • Wee Dangerous JohnWee Dangerous John Posts: 1,605
    edited November 2018
    Just thought I'd nudge in here with a little tip, when DAZ does an update for DAZ Studio or Hexagon you may have to change your preferences in each app for the Hex-DS bridge to work properly. I've done a screen grab of my preferences.
    Like Jonny says, the locatons change if you are using 32 or 64 bit machnes.
    Edit - Took me ages to load this picture properly - Getting old LOL
    1510 x 504 - 252K
    Post edited by Wee Dangerous John on
