Terrible Render
I rendered the i13 Modern Loft several times and every time it comes out terrible and grainy. See Example..
I also rendered some of i13 other products and they rendered fine.
I used Iray memory. What could be wrong?
  • FishtalesFishtales Posts: 6,245
    You haven't let it render long enough. Change the render time and max samples by adding a few zeros to them.
  • How are you lighting it?
  • My 3D SpinMy 3D Spin Posts: 611
    edited November 2018
    I am using the default light from the Scene..Other Envirorments from the same author work perfectly..
    Where do i change the render time? It was at 100 procent when it finished rendering..
    It is under Progressive Render/Max Time(secs).
    There are lights loading with the scene, or do you mean the default HDR? I doubt they are Iray lights, specifically, so they may not be providing enough direct light.
  • edited November 2018
    Lot of i13 product are with simple set + ready to render settings with light settings for make "one click render" in Iray with results like promo images...in this product there are 2 light settings day time and night..."one click render" understood as "with minimum settings to do", so he need only to change parameters of progressive render and try again.
    Post edited by marco_pasqualini_foto on
  • Thanks for your help guys-Changing the value of the progressive rendertime did the trick. Image came out perfect this time!
