Iray Ghost Shaders : anybody got it?
xmasrosexmasrose Posts: 1,409
edited October 2018 in The Commons
Iray Ghost Shaders looks interesting, anybody tried it already?
Thank you.
Post edited by xmasrose on
  • I bought it. I dabbled with it a bit yesterday. Had a hard time with lighting. Since the figure goes transparent, backlight shines right through, while front light washes it out. Sharp lines can appear, too, based on light projection. I think it will be cool once I work out the lighting.
  • barbultbarbult Posts: 26,992
    The product page has tips on lighting. It says "These shaders work best in HDRI environments with little to no lighting (in other words, flat color environments). I have included five flat-light HDRI render environments to help get you started. Most of these promotional images were made simply using the included HDRI environments and either the default camera's built-in headlamp or a single photometric distant light added to the scene. Expand your creativity and experiment with other environments and light sets to achieve a variety of different looks."
    Yes, I tried out the included items, but wasn't pleased with the effect. The other HDRIs and lights I was using were for low-light scenes.
    edited October 2018
    I was curious but honestyly I haven’t had much luck with ghost products or low light renders... so I was waiting to see what other people do with it.
  • I'm having a real problem with the clothes on people. Not all figures have nip and gen removal options, and I can't seem to find a way to get the clothes to mask the nudity. The promo images show clothed ghostly figures, but I don't know how that was achieved.
  • RKane_1RKane_1 Posts: 3,039
    Can you get away with simply making those body parts invisible?
    pwGhost rocks! Nice try though;)
  • Peter WadePeter Wade Posts: 1,682
    pwGhost is a really good shader but it doesn't work in Iray. This is the first ghost style shader I've see for Iray. I expect that Iray's insistence that light must always behave realistically makes these sort of effects more difficult than in 3Delight.
    Yup, that's why I said nice try. Actually I'm impressed!
  • xmasrosexmasrose Posts: 1,409
    edited October 2018
    Thank you everyone for your feedback.
    Will wait to get this but it's on my wishlist. (I do have pwGhost for 3delightwink.)
  • BeeMKayBeeMKay Posts: 7,019
    edited October 2018
    I created a similar shader for myself, and what I learned is that it helps a lot if you create a ghostshell for the object you want to ghost and place this pretty much directly below the surface. The ghostshell also needs the ghost shader. I think this also should improve issues with this shader.
    As for lights, put the ghost in the shadows and try to avoid it being hit by any light, and have some dark surface behind it so they stand out better.
    This is a render with my OLD shader, but I think it illustrates the issue. This uses a geoshell with negative setting.
    Post edited by BeeMKay on
    Thank you for the advices, that's very interesting @BeeMKay.
    Your image looks very good.
    Thank you for the input. I've never worked with geoshells. Can you point me to where to learn about making a ghostshell?
  • Thank you! I will work through this and add some new tricks to my skillset. :)
  • ArtiniArtini Posts: 10,730
    edited October 2018
    I actually like this shader. Below is a sample render with medium settings. A bit slow on my GTX 1080 - Rendering Time: 44 minutes 52 seconds
    https://www.daz3d.com/elliandra-for-genesis-3-and-8-female
    https://www.daz3d.com/dforce-nkea-outfit-for-genesis-8-females
    https://www.daz3d.com/boss-pro-light-set-for-portraits-promos
    1080 x 1080 - 149K
    Post edited by Artini on
  • L'AdairL'Adair Posts: 9,479
    @Worlds_Edge was asking about using the Iray Ghost Shaders to create a crystal statuette similar to Lalique Crystal. Here is my first attempt.
    Frosted Crystal Statuette
    As long as you don't go close to the face, you can get away with it. There are only the eyesockets for eyes. Or close the eyes. Be prepared to increase the Refraction Index to around 2.0 to 3,0 depending on the size of the object, and you may want to adjust the Backscattering Roughness if there are multiple objects together like the image above, to create a more uniform look.
    Lighting is just as important here, too. The color of the statuette comes solely from the color in the HDRI. And too bright can wash out the crystal look.
  • Worlds_EdgeWorlds_Edge Posts: 2,153
    That’s stunning @ladair. Really beautiful. Now I want one for my mantle lol
  • Hi, just resurrecting this thread to ask a question.
    I want to do a render of a character with wings made of light, my thought is that the light outlines the edges of the feathers/wings so they look like how etching images on glass or metal do, if that makes sense?
    Would this product achieve that or do I need to come up with another way?
    Kinda like this: https://images.stockcake.com/public/2/3/8/238174b0-b9f4-411e-b3e0-c3ade5b26e21_large/phoenix-rising-majestically-stockcake.jpg
    or this: https://images.stockcake.com/public/c/2/2/c22d83f7-3503-44e3-9bde-4b54ce9abc9d_large/cosmic-golden-phoenix-stockcake.jpg
    Thanks
