Hangman's noose: rigged
Emfan
I need a noose that can be positioned to use with a figure. It can be widened for an image of it being put on the figure, and narrowed and be at the correct angle to be deployed on the figure. The story I have in mind is not an execution, it is a trust game. Thank you.
Sickleyield tied up products come with a posable noose
https://www.daz3d.com/tied-up-2-for-genesis-2
I havent seen one on this website for Gen 3 or above. But there are products on other websites.
They are in the store for both genesis 8 and genesis 3 :) https://www.daz3d.com/tied-up-genesis-8 https://www.daz3d.com/tied-up-genesis-3
The noose itself is not a wearable item, so you can use it on any figure you like.
That said, I wouldn't use that particular noose myself as I don't like the way it looks. Better (in my opinion) to make your own:
Start wih the posable rope product of your choice, Probably Sickleyield's latest, as that can be dforced if you need it to be. Then build the noose out of three separate lengths of rope:
Parent those together and you have a noose that can be posed to do whatever you like. It's probably easiest if you parent the other two bits to the coils - you put that where you want it and then bend the other ropes up and down from there, but the advantage of the three rope approach is that you can swap things around.
