Hangman's noose: rigged
I need a noose that can be positioned to use with a figure.  It can be widened for an image of it being  put on the figure, and narrowed and be at the correct angle to be deployed on the figure.  The story I have in mind is not an execution, it is a trust game.  Thank you.
    Sickleyield tied up products come with a posable noose
  • https://www.daz3d.com/tied-up-2-for-genesis-2
    I havent seen one on this website for Gen 3 or above. But there are products on other websites.
  • Carola OCarola O Posts: 3,862
    They are in the store for both genesis 8 and genesis 3 :) https://www.daz3d.com/tied-up-genesis-8   https://www.daz3d.com/tied-up-genesis-3
  • chris-2599934chris-2599934 Posts: 1,975
    edited October 2018
    The noose itself is not a wearable item, so you can use it on any figure you like.
    That said, I wouldn't use that particular noose myself as I don't like the way it looks. Better (in my opinion) to make your own:
    Start wih the posable rope product of your choice, Probably Sickleyield's latest, as that can be dforced if you need it to be. Then build the noose out of three separate lengths of rope:
    1. A long straight bit that hangs down from the crossbar.
    2. A medium bit that is tightly twisted to form the 13 coils. You might put a black cylinder primitive inside this to make sure no light gets through it.
    3. Another medium bit that goes round the victim's neck.
    Parent those together and you have a noose that can be posed to do whatever you like. It's probably easiest if you parent the other two bits to the coils - you put that where you want it and then bend the other ropes up and down from there, but the advantage of the three rope approach is that you can swap things around.
    Post edited by chris-2599934 on
