Can't edit Assets In Content DB Editor (4.10 Pro)
Visuimag
For some odd reason, I cannot edit assets in the Content DB Editor in DAZ 4.10 Pro (works fine in the 4.10 Beta). See pic for issue.
Any suggestions?
Post edited by Visuimag on
Do the content directories match between versions?
Nah. 4.10 Pro is missing ther CMS Cluster. Don't know how to change that :P
Pro is on the left
Having Content Cluster in the directory set was a new feature, but that shouldn't be an issue as it looks as if the 4.11 value is the default - in 4.10 you can make sure it matches in Edit>Preferences>CMS Settings but I'm fairly sure it will.
They
Yup, Port and Cluster Directory are a match. Just not sure what else is needed to fix it.
Nor me. The items are categoruised, you just can't change the metadata?
Forgive my ignorance, not sure how to do that
*Btw, thank you for working through this with me!
Well, do the items in your content panes have the type tags at top-right (ooh, alliteration) - material, Actor, etc.? And do the presets tabs in property panes and the Smart Content pane have items?
They do
That at least means the CMS is working - but makes it the odder that you can't edit the metadata. If you right-click on a file in the Content Library pane and select Categorise can you in fact move it to another category?
Sure can
Hmmph. Sorry, I don't know what could cause that - especially as it's affecting only the one version of DS. Please open a Technical Support ticket.
Will do
