Can't edit Assets In Content DB Editor (4.10 Pro)
VisuimagVisuimag Posts: 578
For some odd reason, I cannot edit assets in the Content DB Editor in DAZ 4.10 Pro (works fine in the 4.10 Beta). See pic for issue.
Any suggestions?
405 x 664 - 20K
Post edited by Visuimag on
  • Do the content directories match between versions?
  • VisuimagVisuimag Posts: 578
    edited October 2018
    Nah. 4.10 Pro is missing ther CMS Cluster. Don't know how to change that :P
    Pro is on the left
    461 x 458 - 25K
    458 x 453 - 25K
  • Having Content Cluster in the directory set was a new feature, but that shouldn't be an issue as it looks as if the 4.11 value is the default - in 4.10 you can make sure it matches in Edit>Preferences>CMS Settings but I'm fairly sure it will.
    edited October 2018
    They
    Yup, Port and Cluster Directory are a match. Just not sure what else is needed to fix it.
  • Nor me. The items are categoruised, you just can't change the metadata?
    Forgive my ignorance, not sure how to do that
    *Btw, thank you for working through this with me!
  • Well, do the items in your content panes have the type tags at top-right (ooh, alliteration) - material, Actor, etc.? And do the presets tabs in property panes and the Smart Content pane have items?
    They do
  • That at least means the CMS is working - but makes it the odder that you can't edit the metadata. If you right-click on a file in the Content Library pane and select Categorise can you in fact move it to another category?
    Sure can
  • Hmmph. Sorry, I don't know what could cause that - especially as it's affecting only the one version of DS. Please open a Technical Support ticket.
    Will do
