How do i use Morph Loader Pro(DAZ4) To convert clothing?
nokoteb99nokoteb99 Posts: 931
Im using a V4 character which changes the body of the original V4.
i want a dress for V4 to fit into that new body.
How do i make a full body morph of the new v4 body and insert it into the dress. and then make that dress now fit the new V4?
I using DAZ4 pro(it was free)
    To put the morphs that you have added to the body, into the clothing, you would use Transfer Active Morphs, not Morph Loader Pro.
    It depends on how extreme the morph is, but it should certainly help.
  • nokoteb99nokoteb99 Posts: 931
    Didn't quite get what you said.
    But i tried it Transfer Active Morpsh in this way and i don't really know if anything happened cause the dress still doesn't fit the character.
    I hasically have a dress figure and the V4(with a character morph).
    I select V4 and i go to the EDIT menu/Figure/Transfer Active morpsh.
    I don't get any window or nothing for settings.
    And then nothing really happens or does it?
    I looked in the patameters tab of the dress and it doesn't have a Full body morph of my v4 character
    Ok I tried it a different way. First I selected the dress figure.
    And then I went and EDIT/FIGURE/Transfer Active Morpsh and i get this error message
    "You must select a figure built using Parametric Joing Parameters, that either has another item FIt to it or is fit to another item in order to perform this action"
    Don't know why it's not working
  • Richard HaseltineRichard Haseltine Posts: 109,118
    What dress is it? By the error, it would appear to be using the new weight-mapped rigging or it isn't fitted to V4.
    Ok I did it another way.
    Fit the dress to the Victoria( Her body is out of a the dress because it doesn't fit well.
    and then i did the Edit/Figure/Transfer Active Morphs and then it said something about Joints and i said yes.
    and then this time i did see that the dress changed shape alittle but it doesn't realy even get close to the shape of the V4 morphed character.
    Anyway to get a perfect fit?
    Jersey Dress 2 for V4...
    And my V4 has a character morph applied to it which i further enhanced by making larger and wider hips
    Here is what happens when i try it.
    First picture is before i did the transfer Active Morphs.
    Second is after.
    Notice it really isn't doing much.
    329 x 440 - 127K
    358 x 440 - 135K
    I don't have that item to try it, can you give a link to the product?
    Do the V4 morphs appear in the clothing parameters when you apply Transfer Active Morphs? I don't know if you can use Smoothing on Gen4 items or not.
    It's this one
    http://www.renderosity.com/mod/bcs/index.php?ViewProduct=99030
    But i have the feeling even any other clothing that i try wouldn't convert properly to my morphed V4. Maybe even wouldn't conform to any other V4 morph.
    Did you use the correct version of the dress, It does say there is a version in the 2nd zip for DS.
    According to the Product page on that site, there are loads of morphs supplied with the dress.
    For further controlling of the shape, there are together 25 adjustment morphs to help you change every part of the dress easily and freely, and fix many pokethrough problems if apply special movements.
    adj_BreastL
    adj_BreastR
    adj_LStrapFront
    adj_LStrapBack
    adj_LStrapLeng
    adj_RStrapFront
    adj_RStrapBack
    adj_RStrapLeng
    adj_SkirtBack
    adj_SkirtFront
    adj_SkirtL
    adj_SkirtLF
    adj_SkirtLB
    adj_SkirtR
    adj_SkirtRF
    adj_SkirtRB
    adj_SkirtSize
    adj_SkirtLength
    adj_Upper
    adj_Waist
    adj_ChestFront
    adj_ChestLB
    adj_ChestLeft
    adj_ChestRB
    adj_ChestRight
    Have you tried using the built in morphs? What I have posted above, is only a small proportion of them.
    those are control morphs for shaping specific parts but
    i want at least the basic dres shape to fit my new figure and that's not what's happening.
    I think My dress would fit better if it had the same V4 morph++ that i used to create my V4 morph. And then i could dial to adjust to the same values that i used in V4.
    Which was GluteSize and HipSize..
    But when i add those to the dress. They're added but when i move the dial, there is no change whatsoever.
    Is there another way(easy) to put those morphs into the dress and have them work correctly?
    I have Jersey Dress 2 it has Morphs dials that correspond to some of the V4 morphs
    For example GluteSize and HipSize.
    for some reason when i do GluteSize it works, but when i do HipSize nothing happens.
    It has other morphs and they work too, including breast morphs, Voloptous . Just hipsize doesn't work. doesn't make sense.
    What's going on?
    and yeah i'm using the DS version of the dress
    Merged duplicate threads on the issue.
    How did you add the morphs to the dress? Please give the exact sequence of actions you are using to get from loading the content to the results you are seeing.
    Thankks for your help but i FIgured out :)
    It was a great figure out. Now i have smooth dress fit to my desired V4 morph
  • CMacksCMacks Posts: 202
    Please tell us, what did the trick? I'm having the same problem sometimes.
