Smooth Modifier
bloodboybloodboy Posts: 68
I don't know but i don't really like THE smooth Modifier with rigging cloth ..
There IS to much Trouble with it or I'm to stupid .?.
  • Richard HaseltineRichard Haseltine Posts: 111,677
    What do you mean?
    You know I had an aha moment the other day and realised that the smoothing and weightmapping seem to be linked to a certain degree. I've only just started to look at the weightmapping and discovered that it has a smoothing tool in there. Started me wondering about all those hidden options that I couldn't work out...Richard, am I on the right track or have I gone in the wrong direction altogether. When you use the smoothing option in weightmapping it allows you to fix the distortions on the mesh and that's essentially what smoothing is doing it smooths out the distortions. What was it they said about a little knowledge being a dangerous thing? Probably got it all wrong....sorry for the rambling...
    I'm afraid they are different - the smoothing in the weight painting tool is blurring the weight map, so if there's a sharp change in values causing a ridge (as often happens with skirts) the smoothing will average the values out and give a smoother transition.
  • bloodboybloodboy Posts: 68
    I mean THE smoothing modifier really .. Should the weightmapping done without THE smoothing modifier , because it Males a Lot of Trouble , to much Artefacts and Strange Polygons around..
    I assumed you meant that, but you still haven't really explained what the issues are - some pictures might help.
    Here is a example of it .. Sometimes it s on THE breast as well,
    If i add more weight or less , something other IS Bad on different positions ,
    449 x 500 - 32K
    Are you using the Generic or Original Shape Matching option for the smoothing? Have you tried the other?
    Aaah...I was on the wrong track then. Pity I thought I might have finally worked out some of the hidden dials.
    Also if you have the hidden dials showing changing the weight to .70 or .75 helps with some items.
    I Use Genereic ,,
    @Pendraia , where can I find the dials you are talking about ??
    You need to check Show Hidden properties in the Parameters pane option menu - either right-click on the pane's tab, or click the menu button in the top corner.
    thanks Richard...
