Adding to Cart…
All right, thanks. I'll give that a shot.
L'Adair thx that is a more positive note on the future and for deforce on the whole. Cool
Perhaps a dynamic add-on to keep the ends together and split the metal parts to props to parent to Rigid Follow Nodes?
I'll give it a try and report back what I find.
I pulled out the bits and made them objects, then imported them back in and set them up with Rigid Follow Nodes. I even appllied the dynamic add-on to the bits. It didn't work. But now that I reread what you wrote, I'm thinking you meant to set the suspenders as a dynamic add-on… Back to the drawing board!
I'm not sure how the set works - from your comment ealier about needing to keep the straps together I thought they were discontinuous, which is where a separate piece set as a Dyanmic Add-on could be used to tie them together. If they are continuous then ignore that part of my suggestion.
You were correct up to a point; In the back, the tirangular gizmo hides the ends where they come together. In the front, the straps actually thread through the rings and loop back up, ending under the flattened rings. The leather bit at the end of the straps, going through the metal ring and the bits that hold onto the pants is itself a continuous loop. (Sorry, I don't know the correct terminology for the parts of suspenders.)
What I found, applying the dForce Dynamic Surface Add-on to the suspenders, is they ended up in exactly the same position as those without any dForce modifiers. However, with add-on modifier, the shirt was able to intersect the suspenders. In the images below, the beige suspenders are conforming, the gray suspenders have the Dynamic Surface Add-on applied.
Notice the intersect, bottom right.
@zombietaggerung, I've no idea what look you are going for, but even using dForms, the suspenders with the Casual Craze outfit will be somewhat limited in their ability to fall down the arm due to the style of the back, with that "Y" in the back. The suspenders from the Lumberjack Outfit, (comes with either The Brute 8 bundles, if bought one of those,) has an "X" style that may be more conducive to falling off the shoulder. Sadly, it doesn't dForce any better than the Casual Craze suspenders. They are part of the pants, but you can remove those zones with the help of the Geometry Editor.
All right, thank you I really appreciate all your testing. I'll eventually probably get both of them and see if I can figure something out. I was thinking of something like this, except obviously on a man:
An Add-On collides only with the vertices, so if you use it on a visible item it will give poke-through. The idea is to use it as an invisible add-on, linking pieces that would otherwise come apart (e.g. to hold a shirt closed) or adding a reinforcing strut internally (e.g. to keep a pipe or cord round). I wasn't suggesting making an existing part an add-on but creating a very simple add-on to link loose ends, if needed.
I have so much yet to learn!
What I really want to learn is how to make something like the rings of the suspenders keep their shape so that the object can drape without distorting parts that should be rigid. I wonder… Okay, gonna try something else.
Well, my "something else" didn't work.
I'm convinced dForce just isn't ready for something like the suspenders of either this product or the Lumberjack Outfit.
@zombietaggerung, I wish I could have been more help.
It's quite all right. You have gone above and beyond what I could possibly expect. I really appreciate all the effort.
