Wilmap's Shaders Help?????
Faeryl Womyn
At the suggestion of others, I installed Wilmaps shaders in Daz 4.5 and for some reason I can't get them to work. I am wondering if I am placing them in the right folder. I have noticed lately a lack of instructions for adding shaders to the Daz folders and even went to redownload one of Wilmaps packages to check the readme and there are no instructions for installation. I manually install to make sure things go where they are suppose to.
If you can see the shaders in the Content Library pane, that is all you need. They can go into any folder inside the DAZ Studio library folder.
You do know that you have to select the item you want to apply the shader to in the Scene pane AND you have to select the surface in the Surfaces pane as well to apply them? You also need to render the scene in 3Delight to see the result, as the viewport cannot display shaders.
Ooops lol forgot to select in both panes, was only selecting under scene...can not believe I forgot that. Thank you...lol
Easily done :-)
Glad they are working now.
