Retro fitting Gen 8
What do I need to do to retrofit gen 8 clothes to Gen 2 figures
  • FSMCDesignsFSMCDesigns Posts: 12,851
    There is a product by sickleyield for converting from G8 to G3. you can then save it and then autofit it from G3 to G2. Not sure if that method is native or if there is a prooduct since I have that option when I try to fit G3 clothing to G2
    edited August 2018
    I believe there was a G3M and G3F for Genesis 2. You might need those. I might be mistaken tho. If not you'll need to make clones for at least G3 to G2.
    Laurie
    Edit: there is - here is the G3M to G2M Version
    https://www.daz3d.com/genesis-3-male-for-genesis-2-male-s
    https://www.daz3d.com/genesis-3-female-for-genesis-2-female-s
    Post edited by AllenArt on
  • cclesuecclesue Posts: 420
    I can understand fitting from g8 to g3 but once that is done the cloth is on a g3 figure. how do I get just the cloth from there to the g2 figure.
    You save the clothing to the library as a supportasset - figure/prop assets and then load that item to convert to G2
    edited August 2018
    See my post above. There are two G3 to G2 clones in the store you will need. After fitting the cloth to G3, save the clothing as a wearable preset from G3 and then fit THAT to G2 after installing the G3 to G2 clones.
    Laurie
