Show and hide utility
Nathy Design
Hi everybody,
I need to realize a show and hide utility to hide polygon before simulation.
I hide polygon surface.
Have you got a solution to record setting?
What is it? If it's a node, or can be a node, there's a Visible In Render property that will do exactly what you want.
No it isn't node, it a surface group.
I don't think there's a built-in way to hide a group from a preset - it might well be scriptable, but the geometry-handling scripting areas seem to be being worked on at the moment.
