Timing Fenric's ERC
I'm using Fenric's ERC Chain Modifier with a 1 frame time delay to create bends in a mouse's tail.
Since the tail has many segments, that means it takes many frames before the bend propagates through.
Is there a way within ERC to start this ahead of time, so the mouse's tail is bent at the beginning?
(I could potentially put this into an NLA clip and slide that past beginning of timeline - or simply start my renders from later in the timeline - but didn't know if there was a solution built in - like a 'pre-run' in particle systems)
Thanks
  • HeadwaxHeadwax Posts: 10,544
    Sorry you didnt get an answer to this Mosk, maybe Fenric himself could help?
