Reorganize categories?
Hello!
I try to move the Content to a other HDD and it dosn´t work. I delete all and try a new installation and I have a problem:
- In the products folder I see the content vom 0 -> Z and I can install the products.
- In the Categories folder I see the folder but every folder is emty.
- If I use the search function there ist no result.
What can I do?
Regards
  • How did you install - with Install Manager or within Daz Studio? Can you see the content under Daz Studio Formats, selecting the content diectory you installed to (Daz Connect if you installed within DS)?
  • I use Daz Studio with Connect.
    Try to install Infogal and ToonCow. I found the products in "I" and "T" but not in the categories.
    1920 x 1040 - 192K
    1920 x 1040 - 176K
  • It doesn't lok as Infor Gal has proper categorisation - there are no content type tags at top-right of the thumbnail - but toon Cow looks OK. If you right-click you should have Show Asset In options, see what they give you.
  • OK. Thanke you
